Ignore - ok now - Can't upload files to webspace.
mikeyd
[EDIT]
All of a sudden it works, Please ignore.
I have been a plusnet user for nearly a month and would now like to take advantage of my free webspace.  I am on option 2
I think I am doing everything right, but before I raise a ticket can someone check I am not doing something stupid.
I have tried ftp.plus.net and ftp2.plus.net
My username is the same as I use to get into the member centre section to see my useage etc.
The password is also the same one I use for the member centre
Do I need to anything first to 'enable' my webspace?
Thanks in advance
Below cut&pasted from dos box with username changed.
C:\Documents and Settings\Mike>ftp ftp2.plus.net
Connected to ftp2.plus.net.
220-PLEASE NOTE: If you have a non-subscription account you
220-will only be able to login to this ftp server if you are
220-dialled into our network.
220-
220-A Maximum of 4 concurrent connections are allowed to this
220-server, each session is limited to 64KB/s downloads and
220-32KB/s uploads.
220 Plus.Net FTP2 Server #1 ready
User (ftp2.plus.net:(none)): xxxxxxxxx
331 Password required for xxxxxxxxx.
Password:
530 Login incorrect.
Login failed.
