IPS Tag change required
Fixxxer
I'm in the process of transferring my domain and require an IPS Tag change.
18 REPLIES 18
knowdice
Re: IPS Tag change required
@Fixxxer
I don't know if your domain is a .co.uk but these notes from Google may help....even if you are not going to use Google 😃
Transfer .co.uk & .uk domains
nominet.uk/transferring-your-domain-name/
The "catch 22" - First, sign into your Online Services account. Then follow these simple steps: 😨
Fixes: 587
@knowdice that nominet link is for transferring ownership of a domain not transferring a domain to a different registrar
knowdice
Wouldn't you need  to do that before moving away from Plusnet?
Fixes: 587
No, Plusnet don't own the domain, you do!. You just need to get Plusnet to change the IPSTAG to that of the new registrar.
Fixxxer
@knowdice
I too found similar information, as for sign everything seems to infer that it's likely to be [email protected] replacing isp.co.uk with provider. However this may not be the solution we're looking for, hopefully a staff member will spot our posts and intervene.
knowdice
@MisterW
That's good to know, thanks 😎
knowdice
A bit of a thread hijack...
When we move our domain away from Plusnet, can we still use the Plusnet mail server mx.avasin.plus.net temporarily?
@Fixxxer Any luck with getting your Tag changed?
Fixes: 392
@knowdice Not a good idea - you should use your domain hosts.
knowdice
It's just planning whether to transfer the domain and do the mail service at the same time or do it one step at a time....
Fixes: 587
Moving the domain registration SHOULD not affect the PN email hosting. However, once you change the nameservers to the new hosting, then the PN mail servers will no longer accept email for the domain.
The best approach is to setup the email hosting account , with any mailboxes and aliases, first, then transfer the domain registration. You are then in a position to switch nameservers at any point should there be any loss of the PN email hosting.
Fixes: 392
If it were me, I would do them together - less hassle, IMO.
EDIT - @MisterW beat me to it, with a more informed response.
knowdice
@jab1  & @MisterW
Thank you both, Its helped me greatly to clarify the best way to go with this.
So, just waiting for new hardware to come in then its all systems go.
Fixxxer
@knowdice
Once my IPS Tag is sorted I'm hoping to set up a catch all and forward emails while I consider email hosting options. I was hoping to move to a residential fibre service while there's still capacity in my local cabinet.
Tags (1)
Fixxxer
@knowdice
Unfortunately no progress on the IPS Tag change yet, just hoping to get the attention of helpdesk staff who can make it happen.
