I would like to use a Domain I have registered with you on a Wordress.Com site
MichaelLeete
Hello,
I have tried to follow the Wordpress instructions to do this myself https://en.support.wordpress.com/map-existing-domain/
It tells to replace any existing name servers with these three domain name server (DNS) addresses
NS1.WORDPRESS.COM
NS2.WORDPRESS.COM
NS3.WORDPRESS.COM
I can't see anywhere where I can do this.
Would appreciate some help
Michael
6 REPLIES 6
bobpullen
Fixes: 291
Re: I would like to use a Domain I have registered with you on a Wordress.Com site
It's not possible I'm afraid Michael, without transferring your domain to another registrar.
MichaelLeete
Thanks for the quick reply Bob.
Two questions.
1. When I find a new registrar is transfer to them a simple process?
2. Will my website that you host still be accessible on my other domains?
Michael
bobpullen
Fixes: 291
Is it a .uk domain you have?
MichaelLeete
Hi Bob
Yes its classictrials.co.uk
Michael
bobpullen
Fixes: 291
In which case it's straight-forward. You just need to use the transfer option in the Member Centre and enter the IPS Tag of the registrar you're moving to. If that's not available then you can raise a ticket and we'll arrange it manually.
You Plusnet-hosted website will still be accessible as www.<username>.plus.com.
MichaelLeete
Thanks Bob you have been very helpful.
I remember you were very helpful a good few years ago as well.
Michael
