I going to get fibre
- Everything else
- I going to get fibre
06-10-2019 11:07 AM
Hi there .
Is there anyone who got fibre from plusnet used anything that's on the market to boost broadband speed all around the house and outside . If so could you tell me which you have used and how much do they improve the speed . Thank you . Robert.
Re: I going to get fibre
06-10-2019 12:22 PM
@Robert127 Welcome to the forum.
The first thing to realise is that the maximum speed you will get depends on how far your property is from the local BT fibre cabinet and the quality of the line. This will determine your maximum download speed. There is nothing you can do to improve this.
If you connect devices to your router with Ethernet cable you will get this maximum speed, unless you live in a palace regardless of distance and location. I have installed Ethernet cabling for streaming devices such as my Amazon Fire TV.
If you are thinking mainly about wireless then there is a whole range of ways to improve things. For example, a better router, wireless extenders, wireless access points, powerline units or a wireless mesh system. The most cost effective system is dependent on your property and your budget.
I would suggest that when your fibre is up and running and if you have area of poor speed then you come back here with a description of your problem and a few details regarding walls and distance from the router for advice.
06-10-2019 5:10 PM
Put your number into this site its a BT wholesale cabinet checker and see what comes up for VDSL https://www.dslchecker.bt.com/
That should give you a rough idea
The next thing that will have an effect is the router, as well as router positioning. In an ideal world the router will be in the centre of your house, not tucked on a shelf, not shoved in a corner, behind a TV etc etc
Then theres the property itself, is it an old building with thick stone walls? modern building with insulated material in the walls ( ie foil type panels)? all of those can have an effect
06-10-2019 8:02 PM
At present I have bt fibre the wifi goes way past my garden . It's stone built terrace house with insulated walls all floors and ceilings . Before I had virgin media And I got no wifi outside with the door open standing outside by the door . I was thinking of getting something to boost the wifi as I know no other hub will preform as good as bt wifi hub . With virgin media wifi the further away from the hub speeds go down but with bt the speed is the same anywhere I am in my house including the seller and attic bedroom .
That's the reason I have asked this question . I am expecting the wifi to do the same with plusnet as it does with virginmedia you loose spend the further away from the hub in the house . Thank you both for your help .
All the best Robert
06-10-2019 9:18 PM
If you have a BT Hub that works for you, then why not use it if you move to PN.
06-10-2019 9:19 PM
With your BT HUB, what model do you have?
Some ( if not all) are compatable with plusnet ( and other ISps) so it may be a case of keeping the plusnet one in its box ( as a spare) and using the Hub 6 ( or whatever)
All you need to do is change the username/password in the connection settings, your wifi names (ssid) and password should stay the same meaning that you wont need to change the settings on all your devices
07-10-2019 8:17 AM
On the day of the change over from bt to plusnet my local exchange with switch off my line connection to bt . Then switch over to plusnet equipment from the exchange . This could mean that I won't get the same wifi speed as I get now due to no bt connection .
I have now got two bt hub 6 which I will use first as it's a better hub . The reason I have two hubs If their is a problem and it's the hub it's fix straight away . This could save me paying for a engineer visit over £100.00 . Thank you . Robert
07-10-2019 9:57 AM
The WiFi signal comes from your router, not the exchange - so if you use the same router the WiFi signal strength will be exactly the same no matter what ISP you use.
07-10-2019 10:13 AM
Moderators Note
This topic has been moved from Fibre to Everything Else, as it's not an issue with a fibre connection.
07-10-2019 10:22 AM - edited 07-10-2019 10:25 AM
The solution to your query is a no brainer, use a Smarthub 6. Many of us use them instead of the Plusnet Hub One, which is really an old BT Home Hub 5a with tweeked flaky firmware.
Setting instructions are here. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85... Just take note of when to plug in the dsl cable, some people plug it in too early then claim that it won't work with Plusnet.
