I can no longer access http://sputniknews.com/ - likely ISP censorship
- Everything else
- Re: I can no longer access http://sputniknews.com/...
- « Previous
- 1
- 2
- Next »
Re: I can no longer access http://sputniknews.com/ - likely ISP censorship
21-03-2022 7:28 PM - edited 21-03-2022 7:35 PM
> Out of curiosity I had a look around RT to see what propaganda
All media sources have some sort of inherent propaganda or biases, even the BBC.
What I find more concerning is censorship that forbids see a different point of view.
No it doesn't, it's likely blocked by BT
Ok thanks anyway.
Message 16 of 17
(1,037 Views)
21-03-2022 11:26 PM
Normal connection times out but it works fine and fast through kproxy.
- « Previous
- 1
- 2
- Next »
- Everything else
