Hub One Port Forwarding
carolsmith7
I have recently changed from ADSL to fibre optic and I have had to reconnect my heatmiser equipment. I have managed to connect to WIFI but the instructions state that I have to forward port 8082 to the IP address of my Multi -link which is 192.168.1.50 to enable remote access.  I go into manage games and applications- add new game application- but I am unsure what to enter in the port range and translate to. Could anybody help?
3 REPLIES 3
bobpullen
Fixes: 288
Re: Hub One Port Forwarding
This should help.
carolsmith7
Thank you for your help. I have nearly completed all the steps however I cannot assign the port forwarding to my device as is does not appear to be listed in my wireless connection.
carolsmith7
Please ignore the last post I have now assigned the port forwarding to the device successfully. Thank you for your help.
