How to set a timer
- Everything else
- How to set a timer
How to set a timer
16-04-2023 8:54 PM
I need to set a timer on my internet as my son is staying up most of the night, I can’t switch it off at the wall because it’s behind a partioned wall, I tried a plug in timer but the Wi-Fi wouldn’t work on it, after I pulled the fire etc out to get it in! 🤦🏼♀️
Labels:
Message 1 of 3
(2,659 Views)
2 REPLIES 2
Re: How to set a timer
17-04-2023 8:12 AM
Moderators Note
This topic has been moved from Broadband to Everything Else
Message 2 of 3
(2,612 Views)
17-04-2023 10:26 AM
On the Plusnet Hub 2 you can set a per device timer.
It is located in Home > Advanced Settings > Access Control
http://192.168.1.254/bt_access_control.htm
