How to redirect hosted domain emails to a specific email address?
witchole
I have a domain hosted with Plusnet, and the emails for this domain are pointing to my Plusnet email account (mx.avasin.plus.net).
Currently one particular email address for the domain has been configured to be redirected to a specific email address, and others go to the Plusnet catchall account.
I vaguely remember having to contact support to set up the particular email redirection for me a few years ago, is that still the case? I would now like to create a new particular email address for this domain.
Tags (2)
2 REPLIES 2
Fixes: 525
Re: How to redirect hosted domain emails to a specific email address?
@witchole
If I understand you correctly , you mean you have a mailbox for one specific email address and another mailbox which is the catchall ?
Note that mailboxes are common between your native <accountname>.plus.com and any hosted domain e.g mydomain.co.uk
All you need to do is create a new mailbox using the Manage my mail link in the member centre.
Login, got to the 'Manage Account' tab and then the 'Manage My Mailboxes' link. On the summary tab, click the Create New Email Address, select Next and selct the Deiver to a new mailbox , click Next and enter the password (note the restrictions!) for the new mailbox. Click next and your new mailbox should be there
Hope that helps
witchole
Ah, brilliant, why didn't I think of that?
Worked perfectly, thank you so much!
