How to power my Raspberry Pi through router.
FIXED- Subscribe to RSS Feed
- Everything else
- How to power my Raspberry Pi through router.
09-07-2020 12:50 PM
So my end goal is to power my RPi through my plusnet hub, this way I can connect to it when needed etc.
- Raspberry Pi Zero.
What I am currently trying:
Plugging in the USB into the back of the hub where the USB slot is; this is not working.
Fixed! Go to the fix.
Re: How to power my Raspberry Pi through router.
09-07-2020 1:08 PM
I'd be fairly sure that the USB port on the router won't supply enough power for the RPi.
09-07-2020 1:14 PM
That was one of my assumptions, do you know if there is any problem with the following adapter https://www.argos.co.uk/product/1420579 connecting to the plusnet hub? When I try to connect via this it does not connect to the hub but when I try to connect to my mobile hotspot that works perfectly fine.
09-07-2020 1:21 PM
That adapter ought to connect fine to the PN Hub. If it's a Hub one then try splitting the 2.4ghz and 5ghz bands by giving the 5ghz one a different SSID. That adapter isn't 5ghz capable and sometimes having both on the same SSID can confuse some adapters.
- Everything else
