How to password a web folders ?
- Everything else
- How to password a web folders ?
05-05-2008 4:16 PM
I’m using Microsoft Notepad to create the files, and either Windows Explorer or CuteFTP to transfer them. Yes, I think I am meticulously following the instructions on the Help Pages.
Any ideas anyone ? Has anyone used it recently on F9 ?
Re: How to password a web folders ?
11-05-2008 12:32 AM
I am not a huge user of htaccess but,
I gather that permissions are crucial for them to even work, wrong permissions and they wont pick up.
(I maybe wrong)
Humour me and check (this may sound really stupid):
1. I myself cannot create .htaccess files locally due to FS constraints on Windows,
so I assume you are altering the name once uploaded. Make sure the prefix '.' is in there else it wont be picked up by Apache.
2. if they need to be chmoded to 777 or something, just so that the separate Apache User cant argue at all.
although 644 (usually default permissions) should be fine as all Read Permissions are granted 😕
Sorry if none of that helps.
Jim,
17-05-2008 10:25 AM
Yes, I am uploading htaccess.txt then changing it to .htacces
At the same time I change the properties to (Owner) read/write/execute , and all others just read.
The same with the password file. Sadly it just doesn't seem to work.
Anyone else tried this recently ?
17-05-2008 9:12 PM
Can you post your .htaccess file and also say what directory it is in.
The path to the .htpasswd file you use should match what the pwd command gives you on the command line.
17-05-2008 10:47 PM
I can see and read the '.' files OK. Just install 'Ext2IFS_1_11.exe' which I use to read my linux partitions.
17-05-2008 11:07 PM
The guides do assume a little prior knowledge. With me it was trial and error until it worked
Customer and Forum Moderator. Windows 10 Firefox 100.0.2 (64-bit (64-bit)
18-05-2008 10:33 AM
this is what I have set:
[quote=.htaccess]
AuthUserFile /share/isp/**1**/www/**2**/**3**/htdocs/**4**/.htpasswd
AuthName "Please log on"
AuthType Basic
require valid-user
Where:
**1** = "Plusnet" "Force9" or "freeonline"
**2** = The first two letters of your username
**3** = The whole of your username
**4** = The directory which you want to password protect. This must be everything after www.username.co.uk/
[quote=.htpasswd]
**1**:**2**
**3**:**4**
Where:
**1** = username 1
**2** = encrypted password 1
**3** = username 2
**4** = encrypted password 2
I encrypted passwords using http://usertools.plus.net/htpasswd/index.php, which is the plusnet version.
Just type your username and password in, and click submit.
Do it until you have all your usernames and passwords and then click submit again with the fields empty, and you will get the exact text you need to put into .htpassword.
I then transferred both htaccess.txt and htpassword.txt using windows explorer, into the directory which is shown in .htaccess. You have to put the two files into the directory which you want to password protect.#
The two files should now disappear, as they have been hidden.
To use Windows Explorer to transfer things to your website, just type ftp:// and then your url (ie. ftp://www.username.co.uk) into the bar at the top, and it will ask you for your login password for plusnet. I find this is the easiest way for me to transfer as it works in the same way as windows explorer normally works, and there isn't any complicated details which you need to look at.
Hopefully this will be of some help to you.
18-05-2008 11:04 AM
I've messsed up the '.' files and locked myself out of the www. access.
Can you suggest how I can view, edit or delete the .htaccess and .htpasswd using IE7 ftp so I could try again? ftp access is OK but they are hidden (or reconfigured)
18-05-2008 11:19 AM
Just use the dos ftp
ftp ftp.plus.net
<enter username & password>
ftp> cd htdocs/yourdirectory
ftp> del .htaccess
18-05-2008 11:30 AM
To replace them, just upload the correct form, and replace in the same way as you would in windows explorer.
19-05-2008 7:51 PM
19-05-2008 10:53 PM
If it still doesn't work, if you post the text you have for .htaccess in the forum, I can check if you have it all correct.
20-05-2008 10:36 AM
20-05-2008 11:34 AM
What is the text in your .htaccess file?
20-05-2008 8:12 PM
- Everything else
