How to install WordPress on the server?
- Everything else
- How to install WordPress on the server?
Re: How to install WordPress on the server?
13-02-2010 4:40 PM
That looks simple enough, I will try that... Thank you!
Francis
13-02-2010 5:35 PM
I just done what you have told me, and still do not work I have been taking pics of everything I have been doing, so judge for yourselves
Thank you anyway!
Francis
Here go the pics.
13-02-2010 6:19 PM
Gabe
13-02-2010 7:36 PM
Posting some pics
Francis
Thank you Spider and everyone involved to help me out with this
13-02-2010 8:49 PM
13-02-2010 10:58 PM
Francis
13-02-2010 11:19 PM
David
14-02-2010 2:42 AM
First thing, how do I make my blog to appear as http://www.<username>; Let me show you what I mean!
This link works:
http://ccgi.galrey.plus.com/blog1/
This link doesn't work:
http://www.galrey.plus.com/blog1/
Second question I tryed to upload an image and it wouldn't upload, infact my browaser went dead on me. It even wouldn't start even by closing it and restarting.
Infact I had to shut down my broadband connection, and restart then my browser started working again.
14-02-2010 3:12 AM
14-02-2010 8:11 AM
This link works:
ccgi.galrey & www.galrey websites are hosted on different servers. The only way I know of pointing http://www.galrey.plus.com/blog1/ to http://ccgi.galrey.plus.com/blog1/ is to set up a redirect. You would have to create a .htaccess file will the following line:
Redirect 301 /blog1 http://ccgi.galrey.plus.com/blog1/
the .htaccess file then would need to be uploaded to htdocs in www website.
14-02-2010 9:36 AM
14-02-2010 2:28 PM
Quote from: mal0z and if you do decide to change ISP at some in the future, you keep your domain name.
My friend! there is no way that I leave Plusnet... Something terribly wrong must happen first before I do such thing.
The idea of having a domain name, it's very good, infact I do have a domain name that expires next yearand I am not using at the moment,
and it's host by another Web host provider the one I was using before I joined Plusnet and it's call Claranet. As I have said I will try to transfer
it to Plusnet, it's a <domainname>.co.uk
Thank you for the idea
Francis
14-02-2010 2:47 PM
Quote from: Spider
Spider thank you for this sugestion, but I think it will complicate things even more. I quite like the idea from maI0z of using a domain name which I do have, but it's hosted
by another web hosting commpany, I think the best thing to do it's to get it back and transfer it to Plusnet.
Still I haven't had any answers on regard to why I can't upload files(images) to the blog. Do I change the priviliges on setperms.php?
Thank you!
14-02-2010 9:50 PM
http://codex.wordpress.org/Using_Image_and_File_Attachments
You'll find:
Quote Prerequisite for Uploading Files
In order to use all these tools, you have to change the chmod of wp-content folder to 777.
Unfortunately, on the current ccgi platform, that's a really bad idea.
Wordpress has a slightly iffy way of setting file permissions, guessing the correct setting from the containing folder.
Three ways of working round that:
You'll see in the posting mentioned by David that an acceptable alternative to permissions of 710 for folders is 750 (no higher and NOT applied to files). Rather than setting wp-content to 777, as Wordpress suggest, you can safely use 750, just for wp-content and its subfolders. You can use your ftp client (or the setperms script placed in wp-content with $dperm=0710; changed to $dperm=0750;) to change the permissions on wp-content to 750 and recurse into subdirectories, applied to directories only but NOT files.
A second option involves simple edits to three of Wordpress's script files, but I'm guessing you'd prefer to avoid that.
A third option would be to put the images on a non-Plusnet image-hosting site, and link to them with the "From URL" option. That may sound complicated but it saves a lot of bandwidth on Plusnet, and bandwidth can be a bit limiting for image-heavy sites.
In any case, I don't think the upload problem should have crashed your browser. It should just have left a broken image icon on the page.
Gabe
14-02-2010 10:24 PM
OK of course like all of us here love PN
But having you own url makes lots of things easier and tidyer
http://www.galrey.org.uk
instead of
and probably more important simplifies email addresses.
- Everything else
