How to get rid of .htaccess and .htpasswd
- Everything else
- How to get rid of .htaccess and .htpasswd
29-04-2008 4:07 PM
Re: How to get rid of .htaccess and .htpasswd
29-04-2008 4:24 PM
If using WS_FTP you can issue a 'command line' instruction of -la into the little command line window and you should see these miraculously reappear.. then you can just delete them.
30-04-2008 8:54 AM
I'm using windows explorer for the simple FTP functions like setting the properties of my php pages but there is no option to view the 'hidden' files
I'm using MS FrontPage as the editing package for uploading my files.
How do i get to view these 'hidden' files?
30-04-2008 6:16 PM
Quote from: SoulBriski How do i get to view these 'hidden' files?
As I say I use either a Firefox plugin (FireFTP) or usually an old copy of WS_FTP..
You can try the latest version for 30 day trial of WS_FTP from:
http://www.wsftp.com/products/ws_ftp_home/try/
Their help pages show you how to issue the -la comand:
http://support.ipswitch.com/kb/WS-20001229-DM04.htm
FireFox might be the easiest route to go down in terms of it being free
Download from here: http://download.mozilla.org/?product=firefox-2.0.0.14&os=win&lang=en-GB
And install the FIreFTP plugin: http://fireftp.mozdev.org/
And the Tools > Options of that has 'show hidden files'
01-05-2008 8:41 AM
I've never used Firefox, are there any conflicts with IE?
01-05-2008 8:49 AM
The only things it can't do are activeX which is MS/IE specific (i.e. windows update) or if you visit a website that was written specifically for IE.
01-05-2008 9:04 AM
01-05-2008 9:36 AM
Customer and Forum Moderator. Windows 10 Firefox 87.0 (64-bit)
06-05-2008 1:48 PM
eg:
ftp ftp.plus.net
It accepts ls -a which should show all files including those beginning with a dot
09-05-2008 9:14 AM
Thats fixed it for me
- Everything else
