How to change WHOIS contact details?
- Everything else
- How to change WHOIS contact details?
19-11-2013 11:10 AM
Is it possible to update the WHOIS contact details? For some reason its using my old email address and I want to turn that off in the not too distant future...
Message 1 of 3
(1,110 Views)
2 REPLIES 2
Re: How to change WHOIS contact details?
19-11-2013 11:10 AM
you should be able to do it through http://www.nominet.org.uk/
Message 2 of 3
(298 Views)
19-11-2013 4:19 PM
Quote from: dvorak you should be able to do it through http://www.nominet.org.uk/
Since my domain is a .net, I'm guessing nominet.org.uk wouldn't be handling it. Looking at the whois details, it looks like its been registered via eNom - a reseller for Verisign. In any case, I haven't got any login details for nominet, eNom OR Verisign!
Just to clarify - the domain was registered via Plus.Net and the domain is only a few weeks old. It took a while for the domain to get registered for some reason.
Message 3 of 3
(298 Views)
- Everything else
