How to change PHP.ini settings
- Everything else
- How to change PHP.ini settings
02-09-2007 12:30 PM
Sorry if this has already been answered. I did a search on PHP.ini to try to find earlier postings but didn't see anything.
I'm learning PHP and I'd like to change some php.ini settings for my configuration (eg register_globals, which my PHP book strongly recommends should be set to off for security reasons but is currently defaulted to ON).
Can anyone please tell me how to do it?
Thanks.
Thanks.
Message 1 of 2
(2,738 Views)
1 REPLY 1
Re: How to change PHP.ini settings
02-09-2007 1:39 PM
I take it you're using your own web server and not the PlusNet CCGI platform?
If you're using your own web sever, you should find the PHP.ini file in the directory where you installed PHP.
If you're using the PlusNet CCGI platform, you are not able to over-ride their configuration - so it's not possible.
Message 2 of 2
(451 Views)
- Everything else
