How to Delete Notes Parent Directory
- Everything else
- Re: How to Delete Notes Parent Directory
02-10-2012 9:38 AM
I have a small website which I constructed using Dreamweaver 4 (Educational) about 10 years ago. When I view the remote site in Dreamweaver the htdocs/ folder only contains one folder, which is my site. However when I open the site on the web I get a screen:
Index of /
Name Last modified Size Description
Reading CRC/ 27-May-2010 23:40 -
_notes/ 17-Dec-2005 16:44 -
If I click the "notes" it goes to a screen:
Index of /_notes
Parent Directory -
and when I click "Parent Directory" it goes back to the previous screen
I want to delete the "notes" folder, so that people can go directly into my website. I have tried deleting the "notes" folder on the hard drive and then synchronising the whole site using Dreamweaver, but the "notes" folder always remains.
Index of /
Index of /_notes
Parent Directory -
Message 1 of 3
(1,015 Views)
2 REPLIES 2
02-10-2012 10:05 AM
If you put files called index.html in those folders that will prevent the indexes being displayed. You could make the index.html files automatically redirect the user where you want.
Alternatively create a .htaccess file with the line
IndexIgnore *
See http://www.javascriptkit.com/howto/htaccess.shtml - section 11.
IndexIgnore *
Message 2 of 3
(235 Views)
02-10-2012 10:55 AM
To delete the notes folder, you'll need to connect with an FTP client and delete it manually.
Message 3 of 3
(235 Views)
- Everything else
