How often will my plusnet value IP address change.
- Everything else
- Re: How often will my plusnet value IP address cha...
12-11-2012 12:14 PM
I'm wanting to experiment with remote html access to a Raspberry Pi, but reading other posts, it seems that no static IP is available for Plusnet Value customers.
Does this mean I need to check with http://www.whatismyip.com before each experiment?
Or will the IP dynamically assigned by plusnet stay the same whilst the Thompson Gateway remains switched on?
And do plusnet (or another) offer a DNS service which would keep track of changing IP addresses as they are dynamically assigned ?
It would be of interest to hear how other plusnet customers cope with dynamically assigned IP addresses.
Message 1 of 4
(4,235 Views)
3 REPLIES 3
Re: How often will my plusnet value IP address change.
12-11-2012 12:17 PM
Your IP address should remain the same as long as you remain connected, it'll change each time your router disconnects/reconnects.
I don't think the 582n has the ability to do dynamic DNS in the firmware.
Message 2 of 4
(1,588 Views)
12-11-2012 12:42 PM
Thank you Chris. From what you say there should be enough stability for me to experiment.
If I want to go further, then the Paspberry Pi will need a process to periodically update my chosen DNS service provider with the IP address allocated by plusnet.
Message 3 of 4
(1,588 Views)
23-01-2013 1:05 PM
The plusnet Technicolor TG582n does support dynmatic DNS updates. I've got it running fine with dns-o-matic. Various instructions around, but I used https://forums.opendns.com/comments.php?DiscussionID=5437&page=1
Message 4 of 4
(1,588 Views)
- Everything else
