How long connected to PN
rippedoffme
I have seen somewhere the length of time in minutes that I have been connected to PN; but can not remember how to access it.
Anyone know or did I dream it?
4 REPLIES 4
spraxyt
Aspiring Legend
Fixes: 75
Re: How long connected to PN
Do you mean the value shown in your router? For example with the Hub 1 go to 192.168.1.254, then Advanced Settings, Broadband and Internet.
You will have to login using the administration credentials.
David
rippedoffme
Thanks for that,but I was looking for time on PN web site - not total web time. From memory I recall it was in thousands of minutes.
Jonpe
Fixes: 9
@rippedoffme click on your name at the top right of the page you are on (as if you want to log off), then "My profile" in the drop-down menu; the numer of minutes on this forum is near the bottom of the list of stats you then see.
rippedoffme
Thank you Jonpe just what I wanted
Regards Allan
