How full is my webspace?
- Everything else
- How full is my webspace?
27-01-2008 6:42 PM
What provision is available for measuring the fullness of one's web-space?
The ideal would be the equivalent of the TreeSize utility.
Message 1 of 9
(1,815 Views)
8 REPLIES 8
Re: How full is my webspace?
27-01-2008 6:52 PM
In the "My Account" section of the left hand menu select "Website Settings" then select "My Webspace".
This will tell you how much webspace you have available in total, how much you have used and how much is still free.
Unfortunately this only shows how much space has been used on the "homepages" server and does NOT include data for the ccgi or frontpage servers.
Message 2 of 9
(390 Views)
27-01-2008 6:52 PM
For your homepages (www) webspace you can find out how much you are using on the member centre page under website settings -> my webspace. Note: this is not a realtime figure, it s updated once per day overnight.
For ccgi, logon to your cshell prompt and enter du -sh
There is no way to find out what frontpage webspace you are using.
The total for all webspaces should not exceed your products webspace allowance.
Message 3 of 9
(390 Views)
01-02-2008 8:39 PM
This is something I was going to ask: how accurate is the figure cited in "My Webspace"?
According to that, I've used 200MB of my free space. Yet the base version of my sites which I keep on my HDD shows less than 160MB the lot.
I know there are the log files on the server, but they amount to a few KB.
So what's using the difference?
Message 4 of 9
(390 Views)
08-02-2008 8:01 PM
(Follow-up to self)
I raised a ticket about this and got the following:
I'd have expected an announcement about it in Service Status if it's a general issue, but never mind...
Quote The script which updates the stats for the Portal is currently off due to some system issues.
This is likely to be offline for the next 7 days, please accept our apologies .
Message 5 of 9
(390 Views)
13-02-2008 7:45 AM
Morning,
I am pretty sure it was me who responded to your ticket as the figure you quoted is familiar to me. Although i did also have a conversation with someone about the very same thing, it might well have been you.
Message 6 of 9
(390 Views)
13-02-2008 7:31 PM
Evening Pete.
Yes, it was me.
I'm leaving the ticket open until the weekend to see if the script gets re-implemented.
Yes, it was me.
Message 7 of 9
(390 Views)
13-02-2008 7:58 PM
Ah, nice to see you on the forums.
No problem.
No problem.
Message 8 of 9
(390 Views)
17-02-2008 6:44 PM
Well, I don't know what's happening, but I left it until Friday night. No change, so I uploaded a small file to the server, left it there for 24 hours and then deleted it to see if that would jog it.
No joy. It still says 200MB instead of about 150MB. I've updated the ticket, so it's a case of wait and see.
Message 9 of 9
(390 Views)
- Everything else
