How do I copy files on my web space
- Everything else
- How do I copy files on my web space
09-12-2007 4:55 PM
Hello,
I want to copy the contents of one directory to another in my area on ftp.plus.net. Unfortunately I don't seem to be able to telnet into this area ...
Is there any way to initiate a copy on the ftp space? or am I restricted to doing a download first and then an upload to get the stuff copied?
(It is very annoying to try doing it this way because of constant timeouts from the plus net FTP server) - incidentally, does anyone else find this timeout issue on FTP annoying? Why is it so bad?
Thanks,
Alan
Thanks,
Alan
Message 1 of 8
(1,788 Views)
7 REPLIES 7
Re: How do I copy files on my web space
09-12-2007 4:57 PM
I don't find the timeouts annoying - because I don't see any!
Have you tried changing the passive mode setting in your FTP software?
Message 2 of 8
(465 Views)
09-12-2007 5:08 PM
Wow, swift reply 🙂
It gives me hope to think there might be a way to stop the infuriating timeouts!
I'm using Filezilla and passive mode is currently disabled, but I'll try enabling it to see if it makes a difference. The other setting I changed recently that seemed to ease the issue a bit was to disable the 'use multiple connections' option. Could it be my firewall too? (Cyber Armour Personal Firewall - I'll try killing it for a bit while the upload happens)
I'm also still in need of a way to copy files locally using a remote command like cp through telnet if it were possible to telnet into the ftp.plus.net area ...
Message 3 of 8
(465 Views)
09-12-2007 6:16 PM
Passive mode seems to be better disabled (didn't seem to upload at all with passive mode enabled)
I also tried disabling my firewall and virus checker but that didn't affect the timeout situation. I get a timeout every 20 or so transfers ...
I also got this message once or twice ...
'530 Sorry, the maximum number of clients (4) for this user are already connected.' but after a pause and an auto reconnect Filezilla continued to successfully upload more files.
What would be really useful is to get a list of recommended settings for the options of Filezilla that might effect uploads to ftp.plus.net.
I'm also still interested to know if there is any way to initiate a copy on the ftp.plus.net server (I can't telnet in ... is this the same for everyone?)
Message 4 of 8
(465 Views)
09-12-2007 7:02 PM
I just noticed this in my Filezilla FTP log so thought that this might have been something to do with the timeouts ...
so I set 'speed limits' to the values shown in the log - but I'm still getting timeouts ...
I've just also noticed I've got compression turned on ... so I've turned that off - still getting timouts 😞
If it helps to see the log just before a timeout happens ...
Alan
PS Still need to know if I can do a file copy directly on the ftp.plus.net area
Quote Status: Connected with ftp.plus.net. Waiting for welcome message...
Response: 220-PLEASE NOTE: If you have a non-subscription account you
Response: 220-will only be able to login to this ftp server if you are
Response: 220-dialled into our network.
Response: 220-
Response: 220-A Maximum of 4 concurrent connections are allowed to this
Response: 220-server, each session is limited to 64KB/s downloads and
Response: 220-32KB/s uploads.
Response: 220 Plus.Net FTP Server #2 ready
Command: USER giraffeandtiger
Response: 331 Password required for giraffeandtiger.
Command: PASS ********
Response: 230 User giraffeandtiger logged in.
Command: SYST
Response: 215 UNIX Type: L8
Command: FEAT
Response: 211-Features:
Response: MDTM
Response: REST STREAM
Response: SIZE
Response: 211 End
Status: Connected
Quote Status: Starting upload of C:\Data\gbr02321\personal\development\web pages\webpages18\more\past\events\pride_files\image005.wmz
Command: TYPE I
Response: 200 Type set to I
Command: PORT 10,0,0,3,6,22
Response: 200 PORT command successful
Command: STOR image005.wmz
Response: 150 Opening BINARY mode data connection for image005.wmz
Response: 226 Transfer complete.
Status: Upload successful
Status: Starting upload of C:\Data\gbr02321\personal\development\web pages\webpages18\more\past\events\pride_files\image006.gif
Command: TYPE I
Command: PORT 10,0,0,3,6,23
Command: STOR image006.gif
Error: Timeout detected!
Error: Upload failed
Status: Connecting to ftp.plus.net ...
Alan
Message 5 of 8
(465 Views)
09-12-2007 9:33 PM
I think the next thing to try is a different FTP client. Can I suggest you give the FireFTP add-on for Mozilla a go as I have found that pretty reliable.
I'm not aware of any way of copy files on the homepages (ftp.plus.net) server.
Message 6 of 8
(465 Views)
09-12-2007 11:12 PM
Thanks, I'll give it a go.
Message 7 of 8
(465 Views)
10-12-2007 2:32 PM
Hi
For moving files around within my web space, I've found that using Internet Explorer is ok.
Message 8 of 8
(465 Views)
- Everything else
