How can I find out when I got FTTC?
lorisarvendu
Would it be possible to find out from Plusnet when I first got FTTC?  I was with Force9 originally, so was in the first wave when our exchange got FTTC installed. I honestly can't even remember what decade it was!
I don't have an issue, I'm just after the year when our town first got FTTC, and I figured Plusnet might have that information.
Samknows  only says we've got "limited availability" of FTTC, but no "since" like the ADSL.
A tortoise? What's that?
You know what a turtle is? Same thing.
4 REPLIES 4
RealAleMadrid
Fixes: 68
Re: How can I find out when I got FTTC?
@lorisarvendu  Did you not think of looking at your own forum posts🤔
FTTC installed
It was the 24th of October 2011 so quite early in the FTTC rollout.
Fixes: 1,662
Hi there, I've checked our records and 24.10.2011 is indeed the case your FTTC was first installed.
Has it really been that long? Cheesy Cheers for your loyalty and sticking by us!
lorisarvendu
Ha! Never thought I'd mentioned it in my old posts!
Thanks for that.  Yes I'm still with Plusnet. No point in fixing it if it ain't broke.
Fixes: 1,662
You never know what you can dig up around here!
Ah nice, sounds good and makes sense to me.
