How can I connect to my PN broadband while not at home?
FIXED- Subscribe to RSS Feed
- Everything else
- Re: How can I connect to my PN broadband while not...
10-08-2018 8:59 PM
Fixed! Go to the fix.
Re: How can I connect to my PN broadband while not at home?
11-08-2018 12:10 AM
Moderator's note:
Thread moved from Broadband to Everything Else.
Forum Moderator and Customer
11-08-2018 9:54 AM - edited 11-08-2018 10:05 AM
Can you plug your router in? Yes
Can you expect it to work? Don't know
Is using Plusnet's residential services for work contrary to their Terms and Conditions? Yes
11-08-2018 11:32 AM
I wouldn't have thought it would work. A line provisioned with BT Internet would be routed to BT Retail's network fro authentication , it would not be able to authenticate with PN's servers.
I don't see why your VPN wouldn't connect from a BT Internet connection, unless your work system is checking what IP you are connecting from (unlikely!). What VPN client are you using ?
As @Baldrick1 says, using your residential connection continuously for work is strictly against the T & C's although occasional use is ok.
11-08-2018 1:45 PM - edited 11-08-2018 1:46 PM
11-08-2018 1:48 PM
11-08-2018 4:33 PM
Hi @Johndunn
Your Plusnet router would gain synchronization to the telephone exchange however, it would not authenticate (use of broadband username and password being authorized with our server.)
@MisterW the only way this would be the case is if a static IP address was assigned.
It is possible that BT or the router are blocking access to the ports required for VPN but this could only confirmed them.
Thank you.
11-08-2018 4:35 PM
Have you tried doing a search on the BT Forum? This link looks a bit like your problem, the fix may be in message 8. https://community.bt.com/t5/Home-setup-Wi-Fi-network/HomeHub-5-and-Cisco-Anyconnect-VPN-Issue/td-p/1...
14-08-2018 8:45 AM
https://community.bt.com/t5/ADSL-Copper-broadband/Bt-Home-Hub-and-VPN-problem/td-p/114249
- Everything else
