How can I connect to my PN broadband while not at home?
Johndunn
I'm going to be away from home next week and will need to work remotely. I normally use a VPN to access my work network. I will be at a relative's house who uses BT Internet and they obviously have some sort of fire wall and I can't even connect while there. Can I plug my PN modem in at their house and expect it to work? What other options do I have?
8 REPLIES 8
Mav
Fixes: 515
Re: How can I connect to my PN broadband while not at home?
Moderator's note:
Thread moved from Broadband to Everything Else.
Forum Moderator and Customer
Fixes: 418
Can you plug your router in? Yes
Can you expect it to work? Don't know
Is using Plusnet's residential services for work contrary to their Terms and Conditions? Yes
Fixes: 395
I wouldn't have thought it would work. A line provisioned with BT Internet would be routed to BT Retail's network fro authentication , it would not be able to authenticate with PN's servers.
I don't see why your VPN wouldn't connect from a BT Internet connection, unless your work system is checking what IP you are connecting from (unlikely!). What VPN client are you using ?
As @Baldrick1 says, using your residential connection continuously for work is strictly against the T & C's although occasional use is ok.
Johndunn
Thanks for the snark, Baldrick1.
Johndunn
It's a Cisco VPN. I'll have to see why it doesn't play nicely with BT. And I only very occasionally use a VPN for work stuff on my PN connection -- I'm office based -- and will need to work remotely for two days next week.
Jubby
All Star
Fixes: 31
Hi @Johndunn
Your Plusnet router would gain synchronization to the telephone exchange however, it would not authenticate (use of broadband username and password being authorized with our server.)
@MisterW the only way this would be the case is if a static IP address was assigned.
It is possible that BT or the router are blocking access to the ports required for VPN but this could only confirmed them.
Thank you.
 Lewis G
 Infrastructure Operations Professional
Fixes: 418
Have you tried doing a search on the BT Forum? This link looks a bit like your problem, the fix may be in message 8.   https://community.bt.com/t5/Home-setup-Wi-Fi-network/HomeHub-5-and-Cisco-Anyconnect-VPN-Issue/td-p/1...
Johndunn
Thanks for the help all. It was actually the BT Web Help that was interfering. See message 3 here:
https://community.bt.com/t5/ADSL-Copper-broadband/Bt-Home-Hub-and-VPN-problem/td-p/114249
