How are my stats?
- Everything else
- How are my stats?
How are my stats?
08-12-2016 3:45 PM - edited 09-12-2016 1:28 AM
"Cross posted"
hey everyone, ok so first off im not trying to be lazy or anything lol im currently googling all this to try and learn it all myself but id love some feedback from u pros if possible
my adsl checker estimates of 60 down and 16.8 upload lowest on a clean line
Im on an ECI cab and about 500 meters from it.
So for quite some time i had 50 down 6 up on an 80/20 fibre package, Then after some power cuts i was at 30/1.8 and ive had that speed for a few weeks until today when i put the hg612 in, now im getting 45 down and 3.19 up.
Plusnet said my line checks were all fine so iv had 2 bt engineers round but no faults been found, and the only thing the engineer really said was that im probable suffering from crosstalk.
Ive had dslstats up for about an hour and a half and was wondering how my stats look?
DSLAM/MSAN type: IFTN:0xb206 / v0xb206
Modem/router firmware: AnnexA version - A2pv6C038m.d24j
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 1 hours 38 min 9 sec
Resyncs: 0 (since 08 Dec 2016 13:21:40)
Downstream Upstream
Line attenuation (dB): 18.1 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 48084 3792
SNR margin (dB): 6.5 6.1
Power (dBm): -3.4 -3.4
Interleave depth: 1 1
INP: 0 0
G.INP: Not enabled Not enabled
Vectoring status: 5 (VECT_UNCONFIGURED)
RSCorr/RS (%): 0.0025 0.0015
RSUnCorr/RS (%): 0.0001 0.0000
ES/hour: 5.06 6.51
xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 3652 Kbps, Downstream rate = 48604 Kbps
Bearer: 0, Upstream rate = 3615 Kbps, Downstream rate = 48836 Kbps
Discovery Phase (Initial) Band Plan
US: (6,31) (882,1193) (1984,2770)
DS: (33,857) (1218,1959) (2795,4083)
Medley Phase (Final) Band Plan
US: (6,31) (882,1193) (1984,2093)
DS: (41,857) (1218,1959) (2795,4083)
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 3652 kbps 48604 kbps
Actual Aggregate Tx Power: - 3.5 dBm - 3.6 dBm
VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3
Line Attenuation(dB): 0.6 23.3 35.6 N/A N/A 12.8 30.1 47.4
Signal Attenuation(dB): 0.5 23.1 0.0 N/A N/A 12.0 29.8 47.5
SNR Margin(dB): 7.2 6.0 0.0 N/A N/A 6.4 6.4 6.4
TX Power(dBm): -4.5 -18.9 -11.3 N/A N/A 10.6 7.3 7.3
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.5 6.1
Attn(dB): 18.1 0.0
Pwr(dBm): -3.4 -3.4
VDSL2 framing
Bearer 0
MSGc: 18 33
B: 239 118
M: 1 1
T: 64 5
R: 14 16
S: 0.1588 0.9954
L: 12792 1085
😧 1 1
I: 254 135
N: 254 135
Counters
Bearer 0
OHF: 2213977 349322
OHFErr: 16 13
RS: 141669467 1223669
RSCorr: 3605 32
RSUnCorr: 92 0
Bearer 0
HEC: 72 0
OCD: 4 0
LCD: 4 0
Total Cells: 522002596 0
Data Cells: 18477392 0
Drop Cells: 0
Bit Errors: 0 0
ES: 14 13
SES: 0 0
UAS: 486 486
AS: 5649
Bearer 0
INP: 0.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 2.55 16.23
OR: 75.24 19.21
AgR: 48159.59 3810.74
Bitswap: 4104/4105 3/3
Total time = 1 hours 42 min 15 sec
FEC: 3605 32
CRC: 16 13
ES: 14 13
SES: 0 0
UAS: 486 486
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 12 min 15 sec
FEC: 1017 4
CRC: 0 1
ES: 0 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 917 0
CRC: 2 0
ES: 1 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 1 hours 42 min 15 sec
FEC: 3605 32
CRC: 16 13
ES: 14 13
SES: 0 0
UAS: 486 486
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 1 hours 34 min 9 sec
FEC: 3605 32
CRC: 16 13
ES: 14 13
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Re: How are my stats?
09-12-2016 11:59 AM
From what we can see, the stats look ok. Unfortunately, it's likely that you'll be suffering from crosstalk, which is just the nature of the technology.
Is there any problems with the actual performance of your broadband connection at the speeds you're seeing?
Matty
09-12-2016 12:05 PM
There is heres my adsl checker but im getting 45 down 3 up
i really need more upload for work and 3 mb is so slow, 2 bt engineer vists already so i dont feel its worth another (support wanted to book another eng) :(. Why is a big section of my upload bitloading tones missing?
09-12-2016 12:18 PM - edited 09-12-2016 12:22 PM
That doesn't look like cross talk - more interference from somewhere
The tone graph shows two things - a large gap in the 2000 - 2800 band which shouldn't be there and a rather large reduction in bits as it moves up the tone range - compare it to mine which has had a speed reduction caused by crosstalk
These are my stats
Connection speed (kbps): 42576 9998 SNR margin (dB): 6.3 5.1 Power (dBm): 12.8 6.8 Interleave depth: 8 4 INP: 46.00 43.00 G.INP: Enabled Enabled
Do you know which make of cab you have
09-12-2016 12:25 PM
thats what i thought, but im even lower then beginner when it comes to these kinds of things lol im trying to learn it all. Could it be some kind of power interference? yeh im on an ECI cabinet. Could the Power (dBm): -3.7 -3.7 be bad as well?
09-12-2016 1:23 PM
Do you think moving to a 40/10 package would help my upload speed some how? as the download is fine but i need more upload if possible
09-12-2016 2:25 PM
it would have no effect - note that Plusnet don't offer 40/10 only 40/2
09-12-2016 2:26 PM - edited 09-12-2016 2:28 PM
One thing you haven't mentioned
Have you done the quiet line test - dial 17070 option 2 and it should be quiet
Another thing - is the router connected to the master socket or an extension
09-12-2016 3:33 PM
09-12-2016 10:17 PM
I very much doubt it - DLM doesn't work that way
