Hosting domain names
- Everything else
- Re: Hosting domain names
30-09-2007 6:00 AM
It currently says 'awaiting confirmation from registrar' however I need the website URL to be live ASAP. If I change the nameservers for the domain and setup a redirect will this mess up the process with plus net or will I be able to set up what I need to with plus net but still have the url forwarded.
30-09-2007 11:45 AM
I don't understand what you mean by 'change nameservers for the domain'? In order to host it on PN you must set the nameservers to PNs own and you cannot change them to anything else once hosted.
30-09-2007 12:27 PM
I've uploaded a website to my cgi space that I want the domain to point to. I purchased the domain through luckyregister.com, set the name servers in their control panel to point to plus net then raised the ticket to get the domain added to my account.
This is the stage it is at just now however I really need the site to be live using the url. So what I did was change the name servers via luckyregister's control panel to 'park' the domain (think thats the term) on their name servers and forward it to my cgi address.
What I was wondering would be if I could still go through the process outlined in this http://usertools.plus.net/tutorials/id/14 and when set up on plus net, change the name servers on luckyregister to the plus net ones.
30-09-2007 9:41 PM
What you have done is mess up the DNS and hosting on PN by changing the DNS back to your registrar without telling PN you no longer want to host it.
You need to change the names servers back to PN, raise another ticket explaining what you did and asking for the domain to be hosted, then wait for that process to complete (normally 2 or 3 days). Only then can you add the necessary entries in the DNS section of the domain to point the domain to your ccgi webspace.
The tutorial if for domains hosted on PN.
30-09-2007 10:57 PM
I also thought the 2-3 days was for the name server changes to propagate through all DNS servers on the internet and not one specific.
30-09-2007 11:26 PM
There are several parts to the transfer process:
1) Change of DNS to PN
2) getting CS to add the domain to your account and to PN DNS servers.
3) Waiting for the change of hosting to be confirmed.
4) Changing the DNS to point your domain to your CCGI webspace.
It all takes time, the transfer can take several days to complete and the DNS changes up to 48 hours to propogate.
30-09-2007 11:48 PM
The domain has been added to my account as I had the name servers pointing to plus net initially so I'm guessing I'm at the 3rd step which is what 'awaiting confirmation from registrar' means.
Another quick question. Once the domain is live, will I be able to set up a redirect from the default url i.e. ccgi.username.plus.com.
30-09-2007 11:55 PM
As I stated earlier, you need to make sure the name servers are set to PN and raise another ticket explaining what you did and ask CS to fix the problematic transfer.
01-10-2007 12:43 AM
Again, thank you for the advice.
01-10-2007 5:56 AM
Quote from: Peter ...........
Yes you can. I have two domains both of which were set up to be hosted by PN. I then changed the nameservers and set up A records to point back to PN.
01-10-2007 9:51 AM
01-10-2007 2:14 PM
As I see it so long as PN servers, web,ccgi etc, have been setup to accept a domain it's immaterial what nameservers are used. Only need to add the A records for PN servers in the DNS records.
01-10-2007 2:44 PM
Also can I get the default URL ccgi.username.plus.com to redirect or point to my domain.
01-10-2007 2:44 PM
01-10-2007 2:47 PM
- Everything else
