Hosting a domain - but not using plusnets nameservers.
- Everything else
- Re: Hosting a domain - but not using plusnets name...
30-09-2007 3:44 PM
I've registered a domain through godaddy.
I'd like to host this on my webspace/cgi, but would ideally like to for various reasons not use plusnet for nameservice.
Is there any way to setup my webspace, or CGI space, so I can simply point a domain at the IP of the web/shell server, and have it 'just work' ?
(I'd like to use SPF, so I can specify hosts that are authorised to send mail, which as I understand it plusnet doesn't yet allow, and also have some flexibility in case my plusnet account goes wrong for any reason.)
Thanks!
Thanks!
Message 1 of 4
(1,710 Views)
3 REPLIES 3
Re: Hosting a domain - but not using plusnets nameservers.
30-09-2007 8:07 PM
I assume by webspace/ccgi you mean your plusnet webspace and not your own web server running on your ADSL line.
In order to use a domain on your PN webspace it must be hosted and known to plusnets name servers.
PlusNet do not support SPF on their nameservers.
Message 2 of 4
(456 Views)
01-10-2007 6:05 AM
PN has 2 of my domains in their hosting records but my nameservers are pointed to DNS records hosted by www.dnsmadeeasy.com These contain A records that point back to PN.
I also have added SPF records for my mailserver as well as the IP addresses for PN mail servers as I have to use these to send to AOL and Hotmail accounts.
Message 3 of 4
(456 Views)
01-10-2007 9:12 AM
Then you are fortunate and at some point your domains will be removed as they don't exist in PNs name servers.
Message 4 of 4
(456 Views)
- Everything else
