Hosting Ticket
- Everything else
- Hosting Ticket
- « Previous
- 1
- 2
- Next »
Re: Hosting Ticket
09-02-2020 10:08 AM
Hi spraxyt,
" the approach here was common I'd expect to see many articles about it; and I don't. This makes me feel it's wrong."
I don't know what that means ;-(
Re: Hosting Ticket
09-02-2020 10:52 AM
Re: Hosting Ticket
09-02-2020 5:13 PM
Hi folks,
I appreciate all your help but the site has now been down for a week.
Can we fix this tomorrow.
Please call me if you need any help testing.
Regards
Tony
Re: Hosting Ticket
10-02-2020 9:54 AM
Morning Tony, I can confirm your domain is now on the CCGI platform and http://www.ocluk.com is now working. We can't point the domain to a sub-directory so I'd recommend moving the webspace files you want to be visible into the root folder.
Let me know if there are any issues.
Re: Hosting Ticket
10-02-2020 10:25 AM
Hi Gandalf,
I don't think this is correct as I have tried from another browser and my phone and it doesn't work.
Can you confirm when you go to www.ocluk.com or ocluk.com you see the last line of text ending with "(ccgi)" - if not then it is the OLD website and not the ccgi version.
Can someone call me regarding this as I rang firday and was told I would get a call back but didn't.
Regards
Tony
Re: Hosting Ticket
10-02-2020 10:29 AM
Hi Tony, now this is odd because the site again definitely opened following the work we carried out about half an hour ago, the domain address is just spinning now. Just to confirm you've not made any changes in the past 30 minutes?
I'm happy to call you back but I'm not confident this is something I personally can fix, I'm liaising with a colleague.
Also I'm afraid again we can't point a domain to a sub-directory, you'd have to move your files to the root folder, can you confirm you've done this? Apologies for the issues and hassle this causes.
Re: Hosting Ticket
10-02-2020 10:37 AM
Hi Galdalf,
According to someone else we can point to a sub folder, but if its too difficult then I will just reinstall my site in the root /public folder.
I just need the repointing done so I can start the next steps.
I can confirm I haven't changed anything today on the ccgi platform.
Re: Hosting Ticket
10-02-2020 12:06 PM - edited 10-02-2020 12:10 PM
Hi Tony, I understand what you've said however Bob's advised it's not possible to point your domain to a sub-directory (and he knows quite a bit more about webspace than most of us here) edit - at least from our side.
While I can see your website doesn't open in Google Chrome, it is in fact opening fine in Firefox.
Can you confirm which web browser you're using?
Re: Hosting Ticket
10-02-2020 1:32 PM
@TonyOCL, I've just checked this over - and as of this morning - the DNS records look to have been created correctly. Browsing looks OK from where I'm sat, however it can take 24 hours or so for the changes to fully propagate so I'd suggest waiting until tomorrow and shouting up if you've still problems then.
Re: Hosting Ticket
10-02-2020 5:00 PM
Hi Bob,
Now that I believe we are pointing to ccgi, do you have any information on the apache mod rewrites?
Regards
Tony
Re: Hosting Ticket
10-02-2020 9:42 PM
Here's potentially a good place to start.
Re: Hosting Ticket
15-02-2020 4:34 PM
Hi folks,
Thanks to all the site is now moved and active.
I couldn't have done it without the help here.
For anyone reading this later and has the same problem - here is a catchup on what fixed the problem
1) I had a corrupt .htcacess file which was corrected
2) Plusnet took a few attempts at repointing my domain from webspace to ccgi. alls good now
3) added tthe few lines which did the apache repointing to use a sub folder.
Again .. thanks all
Regards
Tony
Re: Hosting Ticket
15-02-2020 4:42 PM
@TonyOCL Excellent! I'm glad to see you've got this all sorted now, and thanks for posting back.
Apologies for the repeated attempts it took us to point your domain to the CCGI platform though.
Let us know if you need any further help.
- « Previous
- 1
- 2
- Next »
