Hosted Website (CCGI) repointing to another host and port number
TonyOCL
Hi folks,
I currently have a domain hosted with plusnet for years, and recently moved it onto CCGI and word press. I know I could repoint it using a CNAME record to another host, but would like to repoint to another host and specify the port number.  For example mydomain.com -> mynewdomain.com:8000
As in the CCGI site we are using PHP, is this possible. or do I need to use the default port numbers?
Thanks in advance
Tony
8 REPLIES 8
Fixes: 1,453
Re: Hosted Website (CCGI) repointing to another host and port number
If you have access to the DNS records then you can do it using SRV records, but iirc you’ll need a sub domain.
TonyOCL
I do have access to the DNS records, but won't that only alter the DNS name and not repoint the port?
I assume you mean the DNS records for the hosted domain under "Additional DNS records (Advanced)"
Regards
Tony
Fixes: 1,453
Have a read of https://en.wikipedia.org/wiki/SRV_record
TonyOCL
Looking at the admin port for a domain hosted by plusnet then I can only specify A, CNAME or MX records not SRV.
That would put this option off the table correct?
Regards
Tony
Fixes: 1,453
Yeah, I've never use the PN DNS tools.
Other option is to have a redirect on load of the mydomain.com to mydomain.com:port.
So if anyone ever hits standard port 80 it gets an auto redirect.
TonyOCL
So basically I will need an nginx type solution on the target server.
Or can the php scripts that are running on the PN CCGI not do this?
Regards
Tony
Fixes: 1,453
Why not just set up a php redirect as the homepage for the site?
header("Location: http://example.com/myOtherPage.php");
die();
TonyOCL
Actually that got me thinking and I did a mixture of this PHP command and also mod_rewrite in the .htaccess files.
Basically the main .htaccess file I had it deciding which folder to go to /folderA /folderB and where I wanted the redirect to the other domain and port, then I just changed the index.php file in that folder to do the redirect.
Thanks for you suggestion and help
Regards
Tony
