Hit Counter
- Everything else
- Hit Counter
Hit Counter
07-01-2009 7:51 PM
My existing website has hit counter which uses FP Extensions and I will need to use alternative counter on PAYH server.
I have tried using the standard PN Web Counter Script but have not been able to get it to work.
I see that CGI is included in the code for this counter and wondered whether this will prevent the counter from working on the PAYH system.
I have seen other counters but if possible would prefer to use one which did not include any ads .
Any help on suitable counter would be appreciated.
Message 1 of 5
(962 Views)
4 REPLIES 4
Re: Hit Counter
07-01-2009 7:57 PM
Some people say site counters make a site look unprofessional -
but not for me to judge
one that seems ok is
http://www.sitemeter.com/
no adverts
no adverts
Message 2 of 5
(253 Views)
Re: Hit Counter
07-01-2009 8:44 PM
Have a look at www.hotscripts.com . Loads of counter scripts on there for Perl, PHP, Python and more.
Message 3 of 5
(253 Views)
Re: Hit Counter
07-01-2009 9:08 PM
Many tor suggestions which are much appreciated..
Both the counters include statistics etc.
If possible, I was hoping to find a counter which just recorded number of visitors.
Message 4 of 5
(253 Views)
Re: Hit Counter
07-01-2009 9:19 PM
sitemeter can do that just as well - but you need to know where people visited from, which search engine etc etc what search words otherwise a simple count is meaningless.
another good one is Google analytics's
http://www.google.com/analytics/
http://www.google.com/support/webmasters/?hl=en_GB
Message 5 of 5
(253 Views)
