I am currently installing an existing joomla website to plusnet but im struggling to find some information to go into the configuration.php file. These are the 3 pieces of information i need with descriptions.
• $mosConfig_absolute_path: This is the absolute server path to your new Joomla! installation. It will probably look something like "/path/to/joomla/installation".
• $mosConfig_cachepath: This is the absolute server path to the cache for your Joomla! installation. It will probably look something like "/path/to/joomla/installation/cache".
• $mosConfig_host: This is the location of the server that hosts your MySQL database. For most instances, this value will be "localhost". If you are unsure, ask your hosting provider.
If anyone can help it would be much appreciated
Thanx
