Help with .htaccess - html to php
- Everything else
- Help with .htaccess - html to php
16-06-2014 11:58 AM
Looking for a simple code for the .htaccess file.
Old site was hosting on plus net under /htdocs all using html files, no problems
New site, using WP and hosting on ccvii.username.plus.com and using .php files, no problem
Need the code to redirect ALL the old html files, now indexed with google to point to the homepage index.php
Ideally each old page to the new php page but if all went to the index.php file, this will be ok.
Many thanks
Richard
Re: Help with .htaccess - html to php
16-06-2014 3:48 PM
How many indexed links are we talking about? If there's only a handful then you could set up 301 redirects by adding entries like this to the .htaccess file in your /public directory:
Redirect 301 [old file path] [new file path]
e.g. this would redirect direct attempts to access your site using the address http://invalid.tld/path to the new address http://invalid.tld/target:
Redirect 301 /path /target
PS. In case you were wondering, I'm the same Bob Pullen that responded to your support ticket earlier. Our helpdesk staff can't typically help with web design/scripting stuff because it's outside of their remit. That's why I thought it best I post here rather than in reply to your ticket.
17-06-2014 7:08 AM
Hi, there are about 80 html listed.
I have a complete list generated by some site map software and can use the txt file to do the redirects.
This didn't work before and I tried the following
Redirect 301 http://www.oakbydesign.co.uk/oldfolder/oldfile.html http://www.oakbydesign.co.uk/newfolder
If I put the redirect http://www.oakbydesign.co.uk/newfolder into any address bar, the relevant page is shown but the actual redirect doesn't seem to generate a 404 error.
I will try and copy and paste the htaccess content later on.
Richard
17-06-2014 7:15 AM
Redirect 301 http://www.oakbydesign.co.uk/oak-interiors/oak-doors/oak-doors.html http://www.oakbydesign.co.uk/products/interiors/oak-doors-frames-architrave/
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ -
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . index.php
</IfModule>
# END WordPress
I have also tried just redirecting the folder
Redirect 301 http://www.oakbydesign.co.uk/oak-interiors/oak-doors/ http://www.oakbydesign.co.uk/products/interiors/oak-doors-frames-architrave/
Is it something to do with the index.php file?
I fult understand html but php looses me a bit.
Richard
17-06-2014 11:21 AM
Let me know if you're still unsure about anything.
17-06-2014 12:32 PM
Thanks for this.
I think it may not have worked before as the full url was put it.
The door folder you have entered on the htaccess file does work, thanks
I will put some others on later to see their effect
Cheers
Richard
20-06-2014 1:05 PM
Everything is working
But....
When I login to phpadmin, it doesn't show any databases. There obviously is, as the website works.
I thought about uninstalling and reinstalling phpadmin but the one and only password I have is not recognised.
Can anyone uninstall it for me or know how to request a password reset?
23-06-2014 3:37 PM
Quote from: oakbydesign Can anyone uninstall it for me or know how to request a password reset?
Your install is pointing to a different database to the one your site is now using.
There was a database under the MySQL Manager instance for your .plus.com domain (phpMyAdmin was pointing here) and a database under the MySQL Manager instance for your .co.uk domain (your website was pointing here). I've now deleted the former to avoid any confusion.
Uninstalling the phpMyAdmin interface is as simple as deleting/renaming the /private/phpmyadmin directory from your webspace. This allows you to reinstall the application using the Control Panel. I've done this on your behalf, creating another install under your .co.uk domain. Problem is, the database still isn't visible
I's suggest you avoid making any other changes whilst I refer the issue to Hostopia.
In the interim, you might want to consider using something like Adminer to manage your database.
23-06-2014 4:59 PM
WordPress access worked again when I checked on Thursday afternoon so I assumed the problem had been fixed. I closed the ticket on Friday afternoon still without a response.
It wasn't until the weekend that I tried to use phpMyAdmin and found it wasn't working.
David
23-06-2014 5:30 PM
- Everything else
