Has BT Wholesale Speedtest Removed "Further Diagnostic" tab
Philipeano
Screenshot taken 27/12/2019Screenshot taken 27/12/2019
There was until quite recently (within last 4 weeks) a "Further Diagnostics" tab to click which gave more detailed results.
This appears to have been removed?Huh
Tags (1)
9 REPLIES 9
billnotben
Re: Has BT Wholesale Speedtest Removed "Further Diagnostic" tab
That's a shame as it was useful to see if you were stuck on the wrong IP profile.
I guess some bright spark decided that if it isn't there you can't be wrong or questioned on it.
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to Everything Else.
Strat
Fixes: 565
I thought it was just me.
Fixes: 1,600
Thanks for flagging this, I've replicated this on my own broadband connection and as far as I'm aware there's been no formal comms about the further diagnostics being removed and it's still part of our fault reporting process.
I've raised this to the relevant team for investigation though and I'll post back when I've got any updates I can share.
Fixes: 1,600
As an update the further diagnostics has been temporarily removed from the speed-tester while work is carried out on it. If I get anything else I can share I’ll be sure to post back. Smiley
billnotben
Well there's nothing there at all now.
Maybe the "fix" is to ditch the tester completely.
Fixes: 1,600
@billnotben Could you elaborate? The speedtester seems to work fine for me: https://speedtest.btwholesale.com Smiley
billnotben
I see from your post the link has changed a bit.
Until a few days ago, and previously, I had been accessing that site via my bookmark http://speedtest.btwholesale.com/
What a difference an "s" makes.😀
And it's good to see that the change has also included the return of the "further diagnostics" button.
Strat
Fixes: 565
Yeah, we have to use the 'secure' version.
