HELP! PHPBB forum in CGI space possibly broken by password reset by support??
- Everything else
- Re: HELP! PHPBB forum in CGI space possibly broken...
26-03-2012 10:01 PM
I asked for my CGI password to set up a second forum in my CGI space.
I have been given the original database password before, but lost it in a PC crash. I couldn't get it this time.
PlusNet reset the CGI password to enable the setting up of a second forum and now my first (rather busy) forum is dead.
When I go to http://ccgi.crazeeworld.plus.com/phpbb1/index.php - the message I get is:
"General Error
SQL ERROR [ mysql4 ]
Access denied for user 'crazeeworld'@'212.159.7.202' (using password: YES) [1045]
An sql error occurred while fetching this page. Please contact an administrator if this problem persists."
Is there a way to repair this forum or has it been killed?
It is on a ticket with support, but I'm checking with you lot too, as you've been very helpful before!
Many thanks for any suggestions to get it working again.
Ian
"General Error
Ian
Message 1 of 6
(2,875 Views)
5 REPLIES 5
Re: HELP! PHPBB forum in CGI space possibly broken by password reset by support??
26-03-2012 10:54 PM
I think it would just be a case of editing config.php to replace the old password with the new.
Gabe
Gabe
Message 2 of 6
(486 Views)
26-03-2012 11:16 PM
... indeed, I think that should do it. Best make sure you save a copy of the current file before changing it, and make a note of the file permissions. Also make sure you download the current file and upload the changed one in ASCII mode, and use a plain text editor when changing it.
David
David
David
Message 3 of 6
(486 Views)
27-03-2012 1:33 PM
PN have admitted they have borked the forum and said they were unable to advise.
Thank God for you guys.
I will have a go at this tonight and advise how i've done.
Many thanks.
Ian
Many thanks.
Ian
Message 4 of 6
(486 Views)
27-03-2012 5:08 PM
Hi guys,
Thanks for your help - it's back up and running.
Cheers all.
Ian
Cheers all.
Ian
Message 5 of 6
(486 Views)
27-03-2012 11:00 PM
Excellent
David
David
David
Message 6 of 6
(486 Views)
- Everything else
