Graphs in webstats missing
- Everything else
- Re: Graphs in webstats missing
07-08-2010 6:43 PM
Graphs are no longer being generated as part of webstats.
Daily and Hourly stack graphs and usage by country pie chart no longer appear, even for months for which they were previously generated.
Will they be reinstated?
A
A
Message 1 of 3
(3,877 Views)
2 REPLIES 2
07-08-2010 8:01 PM
Quote from: arthurm Graphs are no longer being generated as part of webstats.
... still have bar graphs here (and the country pie chart) ... did however notice when a few days back, the colour-headers on tables changed, and extra columns for things like Kb out, Kb in, appeared (all showing zeroes but distorting the tables a bit because of the extra columns being squashed in).
Also added recently (to the right of the pie chart, here) was a listing for Great Britain (UK) currently showing at 5% [in contrast with the usual United Kingdom entry (2%) which also still present].
I figured that maybe the version of Webalizer was being upgraded somehow (given the move to the new server/s as per the post here).
I hadn't made any comment on the changes because I thought it was maybe still "a work in progress" and that however things finished up would probably be better than what we had before. The "Great Britain (UK)" stat seems a definite improvement (more realistic percentage though maybe all the dot coms will still show up as US), not sure about the other factors but had hoped that eventually it would all get evened out and any blips be temporary.
However if some of your stats factors are actually "absent", probably the networks team might need to look at that.
Regards,
Penny.
Penny Rollo * Force 9 from 17/02/98 * PlusNet from 2000 onwards
Project HappyChild - free worksheets, maths, languages, spellings, all sorts - page *here* re linking languages across the world - see also the freeway page
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
Message 2 of 3
(254 Views)
08-08-2010 7:44 PM
All working now.
I use Firefox and the Adblock Plus add-on had blocked the graphs; whitelisting webstats.plus.net solved the problem.
Thanks for the reply, got me pointed in the right direction,
A
A
Message 3 of 3
(254 Views)
- Everything else
