Google Search and Maps showing my location as Airdrie
mexicano
When using Google Search or Maps, on my desktop, my location shows as Airdrie and not the place I live in London. My iphone and ipad shows the correct location though.
I'm using the latest Firefox browser on Windows 10 Pro.
Is anybody else having this problem, and if not, can someone please tell me what I am doing wrong, and how to fix it?
I just want to fix the location so I can get correct results when I search for local stores and places.
Thanks for any assist.
11 REPLIES 11
wisty
Fixes: 8
Re: Google Search and Maps showing my location as Airdrie
Have you recently installed a new router?
I have had this experience when installing a replacement router which someone had used  elsewhere.
Google uses WiFi MAC addresses as well as GPS to identify locations. If the desktop has no GPS (doubtful) then Google presumably defaults to the location it thinks the router is at (i.e Ardrie). I think there is a way to prod Google maps about a wrong location, but I'm not sure about the process.
Mine eventually cleared itself up - but it took several months with me apparently moving between Penzance & Reading at the speed of light.
nozzer
mexicano
No new router. Still using the one PN gave me 2704N.
It's really annoying that when I search, for example, Homebase, it comes up in Airdrie and not in MY location!
I've searches for fixes on this for days but all don't fix it.
mexicano
I've looked up your link and it says it's owned by BT, which I know is correct as PN is owned by BT and it states London but when I do searches in it give me results in Airdrie!. That doesn't help me at all so I do worry about about!
What the point of using Google Search or Maps if I get the wrong information?
I know I can use my iphone to do these but I'm at home so why shouldn't I use my desktop?
nozzer
@mexicano
Use a more comprehensive search, such as Homebase <Mytown>.
mexicano
Yeah that's what I'm already doing. It's just annoying that "my location" in Google doesn't work as it supposed to work.
nozzer
@mexicano
If you're using a laptop you probably aren't using a "true" Google service, just a browser. Google geolocation requires a GPS or other accurate signal to work properly, hence it works on your phone/tablet.
mexicano
But it did work before. I'm not sure when this started but i know that awhile ago I did get the correct search location and results.
As you said, I'm not going to worry about it anymore.
wisty
Fixes: 8
There is a thread in the chrome forums that talks about this.
https://support.google.com/chrome/thread/2114248?hl=en
The last few entries have pointers about what to do.
nozzer
@mexicano
You may find these links useful.
https://dyn.com/blog/finding-yourself-the-challenges-of-accurate-ip-geolocation/
https://www.whatismybrowser.com/faq/location-detection-is-wrong
You will find that sometimes it's accurate, other times not, depending on which way the wind is blowing! 😁
mexicano
@wisty
Thanks for the link. I already found it and it didn't help. I have reported the IP address to Google to see if they can do something but knowing Google I won't hold my breath Smiley
