Google Search and Maps showing my location as Airdrie
- Everything else
- Google Search and Maps showing my location as Aird...
05-03-2020 11:01 AM
When using Google Search or Maps, on my desktop, my location shows as Airdrie and not the place I live in London. My iphone and ipad shows the correct location though.
I'm using the latest Firefox browser on Windows 10 Pro.
Is anybody else having this problem, and if not, can someone please tell me what I am doing wrong, and how to fix it?
I just want to fix the location so I can get correct results when I search for local stores and places.
Thanks for any assist.
Re: Google Search and Maps showing my location as Airdrie
05-03-2020 11:34 AM
Have you recently installed a new router?
I have had this experience when installing a replacement router which someone had used elsewhere.
Google uses WiFi MAC addresses as well as GPS to identify locations. If the desktop has no GPS (doubtful) then Google presumably defaults to the location it thinks the router is at (i.e Ardrie). I think there is a way to prod Google maps about a wrong location, but I'm not sure about the process.
Mine eventually cleared itself up - but it took several months with me apparently moving between Penzance & Reading at the speed of light.
05-03-2020 11:38 AM
05-03-2020 11:45 AM
No new router. Still using the one PN gave me 2704N.
It's really annoying that when I search, for example, Homebase, it comes up in Airdrie and not in MY location!
I've searches for fixes on this for days but all don't fix it.
05-03-2020 11:50 AM
I've looked up your link and it says it's owned by BT, which I know is correct as PN is owned by BT and it states London but when I do searches in it give me results in Airdrie!. That doesn't help me at all so I do worry about about!
What the point of using Google Search or Maps if I get the wrong information?
I know I can use my iphone to do these but I'm at home so why shouldn't I use my desktop?
05-03-2020 12:05 PM
05-03-2020 12:08 PM
Yeah that's what I'm already doing. It's just annoying that "my location" in Google doesn't work as it supposed to work.
05-03-2020 12:12 PM
If you're using a laptop you probably aren't using a "true" Google service, just a browser. Google geolocation requires a GPS or other accurate signal to work properly, hence it works on your phone/tablet.
05-03-2020 12:18 PM
But it did work before. I'm not sure when this started but i know that awhile ago I did get the correct search location and results.
As you said, I'm not going to worry about it anymore.
05-03-2020 12:21 PM
There is a thread in the chrome forums that talks about this.
https://support.google.com/chrome/thread/2114248?hl=en
The last few entries have pointers about what to do.
05-03-2020 12:24 PM
You may find these links useful.
https://dyn.com/blog/finding-yourself-the-challenges-of-accurate-ip-geolocation/
https://www.whatismybrowser.com/faq/location-detection-is-wrong
You will find that sometimes it's accurate, other times not, depending on which way the wind is blowing! 😁
05-03-2020 12:27 PM
Thanks for the link. I already found it and it didn't help. I have reported the IP address to Google to see if they can do something but knowing Google I won't hold my breath
- Everything else
