Gateway Check Issues (2)
Bobsta
The previous Gateway Check Issues thread seems to be locked for new posts.
I've just been assigned a new IP by Plusnet in what seems to be a new (to Plusnet) subnet - 195.213.60.*
The gateway checker fails to recognise this IP, reporting:
"Your IP address seems not to be from a Plusnet brand, hence we cannot detect your gateway.
If this is not correct posting the first three octets of your IP address (195.213.60.*) as a reply to the Gateway Checker Issues topic in the Community forums will help us to diagnose the problem."
... could you update the gateway checker to recognise this IP range please? Thx
3 REPLIES 3
Fixes: 1,483
Re: Gateway Check Issues (2)
Moderators Note
This topic has been moved from Fibre to Everything Else
Fixes: 1,483
iirc the gateway checker is now defunct with the move the new network and doesn’t provide accurate info.
spraxyt
Resting Legend
Fixes: 75
Yes the gateway checker is now obsolete
David
