GDLib 1 or GDLib 2
- Everything else
- GDLib 1 or GDLib 2
GDLib 1 or GDLib 2
15-12-2007 4:15 PM
Which version - if at all - is installed on the servers? Tx.
Message 1 of 4
(1,504 Views)
3 REPLIES 3
Re: GDLib 1 or GDLib 2
16-12-2007 1:28 AM
It is going to be version 1. Deduct this from how the cms I use reacted to changes.
Message 2 of 4
(441 Views)
16-12-2007 5:12 PM
lib GD2 is installed
well, at least is is according to everything that I run.
Message 3 of 4
(441 Views)
16-12-2007 9:08 PM
from phpinfo()
gd
GD Support enabled
GD Version bundled (2.0.28 compatible)
FreeType Support enabled
FreeType Linkage with freetype
T1Lib Support enabled
GIF Read Support enabled
GIF Create Support enabled
JPG Support enabled
PNG Support enabled
WBMP Support enabled
XBM Support enabled
JIS-mapped Japanese Font Support enabled
gd
GD Support enabled
JPG Support enabled
PNG Support enabled
XBM Support enabled
Message 4 of 4
(441 Views)
