GCNAT
s3dbw
GCNAT
Before upgrading to full fibre, does anyone know if Plusnet adopts the GCNAT protocols for IP addresses?  I use Plex a lot and external access requires port forwarding which I understand no longer works under GCNAT.
5 REPLIES 5
Fixes: 387
Re: GCNAT
Plusnet does not, and never has use/used CGNAT.
s3dbw
Re: GCNAT
Great to hear, many thanks for the info
Cheers
outcast
Aspiring Champion
Fixes: 19
Re: GCNAT
It would be far better to NOT open ANY ports (unless your firewall can exclude ALL external IP addresses other than your remote connection) due to the security risk involved.
Instead use a free VPN such as TailScale to provide a secure tunnel from your Plex server to your remote devices.
This video will give you an idea of what is involved - YouTube : Using Plex on a Personal VPN Like Tailscale
s3dbw
Re: GCNAT
Thanks for the info, will have a look at that
regards
Fixes: 1,495
Re: GCNAT
Moderators Note
This topic has been moved from Full Fibre to Everything Else
