Freenetname/Madasafish domain management
- Everything else
- Re: Freenetname/Madasafish domain management
26-10-2019 12:30 PM
Hello all,
Originally took out a domain with Freenetname which subsequently changed to MadAsAFish and finally Plusnet
Having recently revamped our website we have met the brick wall of trying to transfer the domain from the original to the new website. I'm probably missing where it is required, but I can not seem to access the domain management on either FreeNetName or MadAsAFish.
Could anyone suggest best way forward other than open window, chuck computer out?
Many Thanks
Tonka
27-10-2019 8:42 AM
Thanks for getting in touch @tonka236.
So we can look into this further can you PM me the domain name along with an explanation of what you're trying to do?
01-11-2019 8:13 PM
Just rebumping this.
As said, just to gain access to the domain that was previously registered with freenetname.co.uk (www.islamdpottery.co.uk) and then MadAsAFish.co.uk. Wish to connect the domain to a new website we have designed but as it’s been a while since we last accessed the account then we seem unable to access the domain management in order to do this.
I’ll gladly take any advise up to and including not doing technology 😉
02-11-2019 10:52 AM
Apologies for the delayed response @tonka236
After checking with the relevant team I'm afraid you're not able to manage the domain.
At this point I'd recommend transferring the domain out to a new provider.
If you go ahead with this drop me a PM with the IPSTAG and I'll get that arranged for you
- Everything else
