Flash guide
- Everything else
- Flash guide
Flash guide
21-07-2008 9:44 AM
Is there a user guide on this forum explaining how to install flash code?
I have some experience but that was on a Joomla site.
Many thanks
Many thanks
Message 1 of 2
(753 Views)
1 REPLY 1
Re: Flash guide
21-07-2008 2:52 PM
What version of flash as it makes a difference? Most editors you simple insert it in flash you can get it to write the code for you if you compile wit hml option . If you want thee code see http://www.janwright.co.uk/chis/ and view source
Message 2 of 2
(126 Views)
