First time installing Joomla on plusnet
- Everything else
- First time installing Joomla on plusnet
21-03-2011 10:12 AM
Hi
I'm installing a joomla site on plusnet for the first time and I'm encountering a problem which I can't resolve -
The server encountered an internal error and was unable to complete your request.
Error message:
Premature end of script headers: index.php
If you think this is a server error, please contact the webmaster.
Error 500
I've googled and changed permissions to 640 for individual files and 755 for folders but don't know where to go from here
Many thanks in advance
Cheers
Paul
Error message:
Error 500
Cheers
Paul
Message 1 of 7
(7,215 Views)
6 REPLIES 6
Re: First time installing Joomla on plusnet
21-03-2011 2:11 PM
Sections 8 and 9 in the CGI Platform PHP Upgrade FAQ explain the likely cause of this error and give details of file and directory permission requirements.
The script here will help you to set permissions correctly.
Are you trying to install Joomla 1.6.x? I believe that requires MySQL 5 but the version currently available on ccgi is 4.1.11. Joomla 1.5.22 installs OK.
David
Message 2 of 7
(649 Views)
22-03-2011 10:42 AM
Hi Mr Spraxyt,
Thanks for very much for your help - I will have a go tomorrow when I've got access to Plusnet broadband
Cheers
Paul
Cheers
Paul
Message 3 of 7
(649 Views)
25-03-2011 9:22 AM
It's probably something I'm doing wrong, but I've found that I needed 750 (rwxr-x---) for both files and directories (the script linked to above sets the permissions to 700 for files and 710 for directories).
Message 4 of 7
(649 Views)
25-03-2011 1:54 PM
Yup.
Quote from: TomMelly It's probably something I'm doing wrong
sets the permissions to 700 for script files
Quote the script linked to above sets the permissions to 700 for files
750 for particular folders (not files) may occasionally be necessary if a CMS is trying to be too clever by working out the correct chmod for uploaded files from the containing folder, by knocking off the execute bits. See faq.
Gabe
Message 5 of 7
(649 Views)
26-03-2011 6:42 AM
Quote from: Gabe sets the permissions to 700 for script files
Gabe
Thanks Gabe - I'll take a closer look... IIRC I had some other problem with the script (one of the find statements), but Filezilla's recursive permissions made it all a bit moot, so I didn't worry too much.
I'll do some more testing and post back to the relevant thread. Since my install was also a Joomla instance, I'll post anything relevant back here as well, since it might help the OP...
Message 6 of 7
(650 Views)
02-04-2011 4:39 PM
Thanks for the help
However we decided to move hosting providers given the lack of support for Joomla 1.6 and my dislike of the plusnet systems and BT related companies generally.
Thanks again for the help
Cheers
Paul
Cheers
Paul
Message 7 of 7
(650 Views)
- Everything else
