First Web Page blank
- Everything else
- First Web Page blank
30-07-2013 11:05 AM
I tried to open my web site this morning using Chrome and got a blank page. The same thing happened with IE10. Looking at the site with an ftp client the index.html file size was 0 bytes (normally 450)! Something had screwed it up so I replaced it with a copy of the original. This made no difference. Renaming it to index.htm made no difference either.
If I open the site in a browser via http://www.<username>.plus.com/ the screen is blank. However http://www.<username>.plus.com/index.html brings up the first page. ftp is working normally.
Any ideas?
Any ideas?
Message 1 of 3
(1,071 Views)
2 REPLIES 2
Re: First Web Page blank
30-07-2013 1:05 PM
Is there a .htaccess file in your root?
Do you have antivirus software on your PC?
Sounds suspicious.
Gabe
Sounds suspicious.
Gabe
Message 2 of 3
(359 Views)
30-07-2013 2:29 PM
Solved it by clearing the browser caches. However, I don't know why the index.html file had lost its contents. On investigation all other .html files on the site were also 0 bytes! I've made them all read only now in case someone manages to hack in.
There isn't an .htaccess file in the root and I do have antivirus software.
Message 3 of 3
(359 Views)
