FileZilla & htaccess
- Everything else
- Re: FileZilla & htaccess
07-10-2009 1:33 PM
Hi All
How do you get FileZilla Client to show htaccess files on the Server?
I need to download my htaccess file to modify it and back it up, yes I should have backed it up.
The htaccess file that I want to back up is in the main htdocs folder on my f9 account.
Message 1 of 6
(1,663 Views)
5 REPLIES 5
07-10-2009 2:08 PM
I think there's an option in FileZilla to show hidden files and folders - if you turn that on it should show the .htaccess file for you.
Hope that helps,
Hope that helps,
Message 2 of 6
(610 Views)
07-10-2009 2:08 PM
Quote How do you get FileZilla Client to show htaccess files on the Server?
Like this...
Message 3 of 6
(610 Views)
07-10-2009 2:26 PM
Woops geting:
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@plus.net and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
For All sites on my F9 Account
Message 4 of 6
(610 Views)
07-10-2009 2:46 PM
Quote from: Midnight Woops geting:
After modifying your .htaccess file presumably?
Message 5 of 6
(610 Views)
07-10-2009 3:04 PM
Hi bob yes it was, but fixt now
Just added:
To stop sidewiki from Google
errordocument 404 http://www.dyslexia.f9.co.uk/404_error.html
errordocument 500 http://www.dyslexia.f9.co.uk/500_error.html
errordocument 404 http://homepages.force9.net/dyslexia/404_error.html
errordocument 500 http://homepages.force9.net/dyslexia/500_error.html
RewriteCond %{HTTP_USER_AGENT} GTB [NC,OR]
RewriteCond %{HTTP_USER_AGENT} GoogleToolbar [NC]
RewriteRule .* notoolbar.html
Just added:
Message 6 of 6
(610 Views)
- Everything else
