Fibre optic bb and ad blocker prob
ming
Two problems forumites -  first one is how can I find out when we're getting fibre optic broadband here? Last summer they were digging up the road for it, but it doesn't seem to be here yet when I search what's available for my postcode.
Secondly, it keeps saying I can't access plusnet help chat because I have an ad blocker - I don't know how to switch it off, is it easy?
10 REPLIES 10
Fixes: 49
Re: Fibre optic bb and ad blocker prob
Was it OpenReach digging up the road?
What does the following site say for your Post Code?
https://www.homeandbusiness.openreach.co.uk/fibre-broadband/when-can-i-get-fibre?utm_source=Openreac...
@ming as for your Ad Blocker it depends on what one you are using if you are using Adblock Plus (ABP) then you may well have an icon on your browser like you see below.
ABP icon in FireFox on Mac
In this instance just click the blue 'Power' switch to turn it off when you land on plus.net.
ming
It says Activate  - coming soon. TY bmc.
ming
Have done that mook, made no diff. Will try again though.
TY BOTH x
@ming - You must be on the main https://plus.net site when you turn the blocker off. Once you have press F5 to reload the site so the JavaScript used to control the chat application can detect this.
Fixes: 49
@ming
Activate means
"We’re running various quality and safety checks. And we’ll soon be letting communications providers know that super or ultrafast is available in your neighbourhood."
So, unless they find a problem you should soon have FTTC available. I would check the following on a regular basis it you're super keen on higher speeds. Once it shows available it'll also give a speed estimate for your line.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Fixes: 1,600
Hi there.
I'd recommend checking the BT and Openreach sites linked above regarding the fibre availability of your line and once it's showing as available you'll be able to upgrade either through your account or by calling us on 0800 013 2632.
If you want to query the availability further I'd recommend filling out this formwize https://www.formwize.com/run/survey3.cfm?idx=505d040e0b080d though it's possible that Openreach won't be able to tell you any further information.
Hope this helps though.
Fixes: 419
There are various sources of add blockers. Some browsers have it built in and you have to go into the settings to disable it. Also some security software includes this feature and again you have to disable it in the settings.
ming
Yes I think that must be it, nevmind I will just phone in future - no worries. TY!
ming
Ok many thanks!
