Fibre Build Roydon Norfolk
paulfuller19
I have been desperatly waiting and watching for full fibre rollout in my close.
Ive been busy looking at openreach's website tonight and noticed that 1/2 the properties in my close / cul-de-sac have the oppertunity to order as its available.
who do I contact to get my property connected?
5 REPLIES 5
Fixes: 382
Re: Fibre Build Roydon Norfolk
Does it say you can get FTTP - I'm guessing not from your post, but it does seem strange that 'half' the properties can?
@paulfuller19
There is a similar thread over on the BT Forums that includes a possible explanation:
https://community.bt.com/t5/BT-Fibre-broadband/full-fttp-to-my-house/m-p/2431216#M360116
Fixes: 116
@paulfuller19
Are you using the following to check for FTTP available. You need to see WBC FTTP in the left hand column. You can use the Address version to see wht's happening with your neighbours.
Are you currently served by an overhead or underground copper connection?
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to Everything Else
Fixes: 116
@paulfuller19
To add to my previous post  if you are served by an overhead connection is it one pole for the cul-de-sac or more? If pole served do they have a box attached to the top of the pole(s) that looks like this.
This is a 4 port CBT (Connectorized Block Terminal) The number of ports depends on the number of properties it serves.
Something similar is used for underground feeds.
