Failing To Connect - Vista Laptop
Hi All
I’m trying, but failing, to connect a friend’s Vista-running (don’t ask) laptop to the internet through my Plusnet broadband connection.  I’m using my Plusnet username and password, but I’m obviously missing a trick because it won’t connect.   One diagnostic response came up with “check the Service Name field is correct”, but I’m not sure what this should be.   Any help or advice would be gratefully received.
Boz
14 REPLIES 14
Fixes: 7
Re: Failing To Connect - Vista Laptop
Could you confirm how you're physically connecting the laptop? If connecting to a router you shouldn't have to use your PlusNet credentials to connect.
That's RPM to you!!
Hi RPM
Thanks for the reply.   I've connected the laptop to the router through an ethernet cable connection.   At the same time I've disconnected my computer from the router.   When creating the connection on the laptop, the system asks me for a username and password.
Boz
Fixes: 7
So you're saying this 'router' has only one Ethernet port or are you just disconnecting your computer just in case?
Anyway, how is your computer being connected, is it a PPPoE connection?
That's RPM to you!!
Fixes: 28
Boz
Sounds like it's something on the laptop which is asking for a username and password, in which case it won't be your PN credentials.
Ω is where the is
I'm switching off my computer and using another port for the laptop.    Yes, it is being connected through a PPPoE connection.
Boz
@198kHz wrote:
Boz
It only asks for the username and password at the point where I'm trying to obtain a connection.   The plusnet server would surely expect this information.
Boz
Fixes: 28
If I've understood this correctly, you're using your router, on your line, and replacing your PC with your friend's laptop, in which case the router is already "signed in". Apologies if I'm barking up the wrong tree - it wouldn't be the first - or last - time!
Any possibility of a screenshot?
Ω is where the is
I think I'm starting to understand what you're telling me.   If my router is "online", I should be able to plug into my router any other device (pc, laptop etc.) without having to do any setup procedure on that device.   So could there be a fault with the laptop's network adapter?   By the way, how do I do a screenshot on the laptop?
Boz
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
Fixes: 28
Yes, that's the gist of what I was trying to convey. Whether it's a 'fault' or misoperation I wouldn't like to say.
Re the screenshot -
Someone will probably know a better way, but if it was me, I'd plug a USB stick into the laptop, hold down 'Alt' while pressing 'Print Screen' (may be 'Prt Scn' or similar abbreviation - just to the right of F12), which will copy the screen image to the clipboard. Paste it to the USB stick, then insert the stick into your PC, from where you can attach the image to a forum post, or upload to a hosting site (eg Dropbox et al) and post the link.
EDIT  Just a thought: when you say in Message 3 that you're "creating the connection on the laptop", are you clicking on a "Network" or "Internet" or similar icon? As you're using your existing network, I'd have thought you'd just need to open a browser window eg Internet Explorer, Firefox, Chrome etc.
Ω is where the is
So you're saying that I don't need to set up anything on the laptop, and that the diagnostic reference to a "Service Name" is irrelevant.
Thanks for the info about creating a screenshot file.   Tomorrow, I'll show a shot of the screen when I click on the IE icon.
Boz
Fixes: 75
How Internet Explorer connects to the network depends on settings in the Internet Options -> Connections tab. I think the defaults are usually set to use an existing LAN connection, but perhaps it's set for dial-up on your laptop.
I'm on W10 with IE11 available as an option; the Connections tab might be different for IE9 on Vista, but if it helps mine is as follows:
In my case clicking the LAN settings tab shows:
David
Many thanks to you David and all those who have replied.   I'm now talking to you through my friend's laptop which did eventually connect to the internet.    As "198" said, there was no need for usernames and passwords, it was something that I should have checked on "Internet Connections".   The advice from the system was that I should check that SSL and TSL (whatever that means) were both enabled, and I ignored this advice.   When I eventually decided to look at these switches, i found that TSL was not enabled.  By correcting the error, everything burst into life, and I'm now able to communicate with the forum using the laptop.
Thank you once again to all those who took the trouble to reply.
Boz
Fixes: 75
Glad to hear you found the problem. TLS is Transport Layer Security, the protocol that supports (eg) the https communications for this website. SSL (Secure Sockets Layer) is an older version for the same purpose. Thumbs_Up
David
Fixes: 28
Good result.  Smiley
Ω is where the is
