FTTP Plusnet in County Broadband area
Re: FTTP Plusnet in County Broadband area
@Andrew70  on that map also try toggling "Any FTTP provider postcodes",  as yet another supplier also appears to have installations locally in North Lopham !
Andrew70
@Anonymous OK will do thank you, ignore my previous post, I got it wrong way around the handful of connections are indeed Openreach, none CB that probably gets to the bottom of it.
More clearly seen by unticking everything, then ticking "Altnet FTTP (not Openreach or VMO2 or KCOM)"
Narrowing the selection further (toggling every box), I'm seeing your nearby installations listed as -
"Upp FTTP Premises",   "AirBand Fixed Wireless or FTTP",   and   "ITSwisp Fixed Wireless"
RealAleMadrid
Fixes: 66
@Andrew70  I wrote a post around 4:15 but it never got sent because Plusnet had a major DNS failure then. Back online now after changing my DNS server address.
There are a lot of addresses on the NR16 2EP postcode, I checked the first 20 or so and 10 of those have Openreach WBC FTTP available and there are probably more, so Openreach have been installing in that area.
greygit1
I think that's slightly unfair.
BT had to open up to other providers.
Why not the same rules for alt-nets?
Andrew70
I heard from  a couple of people that County Broadband had a period of years (3 perhaps ?) before they are expected to open their network to other providers under a wholesale arrangement.
Ive had a look online but not found any evidence to support this unfortunately. Its a shame as I would like the FTTP but cant take a gamble with CB, where I am they are the only provider.
My area is not in the Openreach plans
corringham
Seasoned Champion
Fixes: 23
@greygit1, BT/OR had market domination so were made to provide wholesale access to their network, otherwise they could/would kill any competition.
Altnets aren't (yet) so dominant - however those that received government funding to build networks in the less commercially viable areas will have to provide wholesale access after a period (2-3 years?). Whether there are any ISPs that will take up that access is a different matter...
