FTP uploads timing out again
- Everything else
- Re: FTP uploads timing out again
12-08-2015 12:44 PM
This has been going on for several days and I have raised the issue with PN.
I know that there is a limit on overall concurrent FTP sessions but it seems unlikely I keep bumping into it without others also being affected.
Has anyone else experienced this in the past week?
12-08-2015 1:17 PM
The problem has been raised with Hostopia, however we're yet to hear back from them.
12-08-2015 2:15 PM
- difficulty of initiating an upload to a Home Pages server, and
- almost impossibility of initiating an FTP from Hostopia CGI to Home Pages
I raised these issues separately because they manifest separately (and in the past they have occurred separately), but it is conceivable that Hostopia is getting timed out from connecting to Home Pages because it a Home Pages FTP problem.
The first is 'PN in-house' and should be relatively easy to confirm.
The second needs support from Hostopia, as you indicate. This is why I created the PHP test script for PN on one of my webpages so that Hostopia can watch things time out for themselves. I would have liked to have created a mirror-image PHP script running from Home Pages to Hostopia, but for obvious reasons this is impossible!
12-08-2015 2:42 PM
This is using the Force9 servers.
David
12-08-2015 4:00 PM
12-08-2015 11:01 PM
At 22.39 last night (wed) I tried to upload a 15KB index.shtml. Below is what Dreamweaver encountered. This is pretty typical.
However, I am going to check on Dreamweaver's FTP settings for my umpteen sites to see if passive FTP is unset or SFTP has got switched on something equally bizarre. Has been known!
Started: 12/08/2015 22:39
Connected to BH website.
Operation timed out. Cancelling...
index.shtml - Put operation successful
File activity complete.
Files updated: 1
Finished: 12/08/2015 22:44
13-08-2015 12:04 AM
David
13-08-2015 8:38 AM
My first attempt with the same 15KB file before work this (Thurs) morning gave:
Started: 13/08/2015 08:16
Files updated: 1
Finished: 13/08/2015 08:22
Five minutes later, the same transfer was instantaneous.
Another one of the same small file two hours later gave:
Started: 13/08/2015 10:06
Files updated: 1
Finished: 13/08/2015 10:11
I don't have any obvious network problems : I synch at around 73Mb and network congestion is rarely noticeable and not a problem.
13-08-2015 10:45 AM
13-08-2015 11:55 AM
However, I got to thinking about ports possibly being blocked - at either end - and FTP trying and trying and...way hey...an unblocked port was found..
More specifically, I wanted to check whether if, in response to DW initiating a control connection on its port 1024 or higher to the server's port 21, the server responds in the usual way by trying to open a data connection from its port 20 to DW's port 1024 (or whatever) + 1 and this port being rejected somewhere (not in my software firewall but perhaps in the router) as incoming traffic to be blocked.
So this morning I told DW to switch to passive FTP for all connections and things seem considerably better - but I will carry on testing...
Vide my other current problem of connecting from Hostopia to Home Pages, I have always used passive FTP in such programmed PHP connections
But the PHP test script ran fautlessly several times earlier this morning so perhaps Hostopia (or PN - see below)have changed something overnight Wed/Thurs.
Both problems reek of either
a. total number of concurrent connections exceeding PN's cap, but this wouldn't explain why I should repeatedly hit the problem and other apparently not
or
b. randomly allocated FTP port numbers sometimes being accepted and sometime blocked (which sounds much more likely). In this case, changing from active to PASV in DW obviously changes the 'who initiates sessions and issues what port numbers' process completely since both control and data TCP sessions are initiated from my end. But it wouldn't affect how Hostopia sessions to Home pages were being blocked unless Hostopia was insisting on using some high-numbered ports which are blocked at the Home Pages server end....?
17-08-2015 2:52 PM
Quote from: decomplexity However, I got to thinking about ports possibly being blocked - at either end - and FTP trying and trying and...way hey...an unblocked port was found..
A Wireshark capture would probably tell you the answer to that question.
Quote from: decomplexity Vide my other current problem of connecting from Hostopia to Home Pages, I have always used passive FTP in such programmed PHP connections
Your Hostopia support ticket is void of any explanation but it has been closed.
- Everything else
