FTP to webspace problem
- Everything else
- Re: FTP to webspace problem
16-07-2014 1:19 AM
It says the server is 'ftp.plus.net'. It says to enter my username (which I presume is <user> if I receive emails to "foo@<user>.plus.com"). It says my password is "The password you log in to this website with", which I know well (else I wouldn't be reading the website ...).
I tried to log in with that user name and password and it fails with:
"530 Login incorrect.
Login failed.
Remote system type is UNIX.
Using binary mode to transfer files.
(I am not actually connected, so I cannot transfer anything).
Is this something that has changed recently (so is the link above out of date)? Or, am I just being dense?
16-07-2014 1:36 AM
Quote from: kdl I tried to log in with that user name and password and it fails with:
"530 Login incorrect."
I don't know if this is connected, but have had a ticket open for about six weeks now, with a similar problem. I used to use dial-up and had a non-subscription account (for which I gather it's necessary to be logged in to PN to upload, if I've understood the FTP message correctly).
Quote 220-PLEASE NOTE: If you have a non-subscription account you 220-will only be able to login to this ftp server if you are 220-dialled into our network.
Now that there's a fibre connection here the FTP server doesn't appear to recognise that the PC is "dialled in to PlusNet" and refuses the connection with the same error message.
Quote PASS (hidden) 530 Login incorrect. Connection failed
I don't know if the issue you're experiencing has a similar cause, suppose it would depend on if you're using legacy "free" webspace and on what type of connection you have, maybe.
Regards,
Penny.
16-07-2014 9:27 AM
Quote from: kdl Is this something that has changed recently (so is the link above out of date)? Or, am I just being dense?
It's not you, I can't log into your account either. Leave it with me...
Quote from: Penny I don't know if this is connected, but have had a ticket open for about six weeks now, with a similar problem.
What's the ticket ID Penny?
16-07-2014 10:36 AM
Quote from: Bob What's the ticket ID Penny?
#86567025 - and getting the same issue with things like freeway, which was the account used before the switch to fibre. Clearly FTP "works" from here to the main site etc., and I haven't changed any of the set-ups on the other FTP accounts, so am assuming/hoping it's nothing I've "done" : /
16-07-2014 12:32 PM
Quote from: Bob
Should be fixed now:
~$ ftp ftp.plus.net
Connected to ftp.plus.net.
220-
220-A Maximum of 4 concurrent connections are allowed to this
220-server, each session is limited to 256KB/s downloads.
220-
220 Plus.Net FTP Server #1 ready
Name (ftp.plus.net:bpullen): l*******
331 Password required for l*******
Password:
230 User l******* logged in
Penny, I'll take a look at your ticket shortly...
16-07-2014 12:37 PM
Quote from: Bob Penny, I'll take a look at your ticket shortly...
I'm able to log into both of your non-subscription accounts from my Plusnet FTTC connection at home. I've a similar suspicion to you as to why you're having problems though. Can you FTP to these accounts now? (I'm guessing you'll be able to).
16-07-2014 12:54 PM
Quote from: Bob I've a similar suspicion to you as to why you're having problems though. Can you FTP to these accounts now? (I'm guessing you'll be able to).
lol
how did you dooo that, just "instant fix"
I'd almost given up hope this would get sorted (ticket going round in circles) and then you wander in, wave your magic wand, and hey presto.
amazing. whatever you did, I am truly grateful : )
16-07-2014 1:26 PM
16-07-2014 1:53 PM
16-07-2014 4:39 PM
16-07-2014 6:03 PM
Very many thanks. I've just dug out the email I got when I moved to the new CGI platform and all the login details are explained there. Obviously I didn't think to look at it until after you'd come to the rescue! Thanks again.
16-07-2014 11:31 PM
Quote from: Bob
Quote from: Bob
Yes, that did it. Thanks.
Out of interest, what was the problem? Password reset? (I have had this account since we were allowed access to the shell - it's entirely possible I changed my password at the command line in the past).
FWIW, as another correspondent has pointed out, that support page also still mentions the old cshell CGI host (which is what rang alarm bells for me to it possibly being out of date). So it does still need updating (if only to give you guys an easier time ;)).
16-07-2014 11:41 PM
Quote from: Penny
Thanks Penny - I think we have similar symptoms, but different problems. However, it sounds like my post helped you get your own problem sorted too, so it's win-win!
Kudos to Bob.
16-07-2014 11:51 PM
Quote from: kdl I think we have similar symptoms, but different problems. However, it sounds like my post helped you get your own problem sorted too
... indeed it did - odd how things work out, sometimes : )
Quote from: kdl Kudos to Bob.
... absolutely.
17-07-2014 11:42 AM
Quote from: kdl Out of interest, what was the problem? Password reset? (I have had this account since we were allowed access to the shell - it's entirely possible I changed my password at the command line in the past).
We've never permitted shell access to the Homepages platform although the problem did seem to be related to your password. I essentially resynced your FTP account with your Member Centre account credentials and it seemed to do the trick.
Quote from: kdl FWIW, as another correspondent has pointed out, that support page also still mentions the old cshell CGI host (which is what rang alarm bells for me to it possibly being out of date). So it does still need updating (if only to give you guys an easier time ;)).
cshell.plus.net is now pointed to the new CGI platform so it should still work for FTP access.
Non-authoritative answer:
Address: 91.136.8.9
- Everything else
